How can I get a screenshot without using the print server?
3707
11
12-18-2018 11:07 AM
MattStayner
I would like to get a screenshot of a map (basemap with layers on top) without using the print server. Is that possible?
Thanks!
Tags (1)
MattStayner
Cool. I will start a conversation over there. Thanks again for your help.
I don't see any way to mark your reply as the correct answer, so I marked it has helpful. Thanks!
ErwinSoekianto
Esri Alum
Matt,
In AppStudio for ArcGIS, the Map Viewer template has this functionality implemented where you can take a look at the source code from, using ArcGIS Runtime SDK for Qt (QML).  It is part of the "Measure" panel functionality.
The source code for that camera button is on MapViewer/views/ScreenShotsView.qml, on the very bottom of the page, called function "takeScreenShot()"
I hope this is helpful,
Erwin
