GeodatabaseSyncTask does not create newest replica
702
03-19-2019 11:16 AM
LaurynasGedminas2
I am using this example code:arcgis-runtime-samples-qt/GenerateGeodatabase.qml at master · Esri/arcgis-runtime-samples-qt · GitHu...
and it does create the replica, but the data is 10-15 min old, and not the latest.
why would that happen?
Params are:
    // create the generate geodatabase parameters
    GenerateGeodatabaseParameters {
        extent: app.centerExtent
        outSpatialReference: SpatialReference { wkid: 4326 }
        returnAttachments: true
        syncModel: "SyncModelGeodatabase"
        // only generate a geodatabase with 1 layer
        layerOptions: [
            GenerateLayerOption {
                layerId: featureLayerId
LucasDanzinger
Esri Frequent Contributor
Hard to say. Do you use versioning with a rec/post operation that might be scheduled? Or perhaps you are editing in different extents than your replicas? As soon as you sync, edits should be applied unless either of those 2 scenarios are happening
