Failed to Start Local Server
8135
11
02-18-2015 09:28 AM
VijdanDemir
Hello, I am new at using ArcGis runtime sdk 10.2.3 for Qt. I am trying MyFirstMap application.   It gives :     failed to start local server runtime in the following locations: /ArcGISRuntime10.2.3/LocalServer32/bin   "USCitiesStates.mpk failed to start" Failed to create local service.
  My license status: 2
My license level : 1
  What can be the problem? I am working on Ubuntu 12.04.
I enabled server logging from the LocalServerUtility but there ar no log files under /tmp.
VijdanDemir
Finally, I have solved my problem.
I add the ARCGISRUNTIMESDKQT_10_2_3="/home..", RUNTIMEHOME="/home/..", ARCH="64" to the /etc/environment file
and restart  computer. It works.
I think running ./init_sdk_qt64.sh before opening Qt Creator does not  work so I was getting the errors.
By adding the variable to /etc/environment it is ok.
But I have one small question more:
I tried the code on two different machines.
The code on desktop pc  works  successfully.
The code on leptop starts server but gives the error " USCitiesStates.mpk failed to start. Failed to create local service."   Any idea ?
Thank in advance.
VijdanDemir
ok.. I found it. Its reason was I  was opening qt creator with sudo.
when open qt creator directly, application runs successfully.
