Error build with xCode
1831
10-27-2016 03:23 AM
AntonioFiume
Dear All,
i using the beta version about ArcGIS SDK for QT.
I created a simple ArcGIS QT Application that show a simple world map with QT Creator.
When i run the Application with QT Creator and Window Kit the app works fine.
Then, I converted the application to run with xCode to deploy the app to my iPhone.
When i run the xCode project the system shows 70 errors.
There are particular procedure to export the Qt Application to xCode or i missing something?
Please let me know if you need some information or screenshot.
Thanks in advance.
Tony
EricBader
Honored Contributor
Hi Tony,
There could be a couple problems.
The first problem could occur if you're trying Qt 5.7.0 with Xcode 8 as it's not supported yet.
The second problem could be that you'll need to clear out any `*.stash` and `*.cache` files from your build area or else Qt may be getting confused on which Xcode to use.
Can you verify and let us know?
AntonioFiume
sorry for delay.
If i create a new project with QT Creator and create a new GIS application works fine.
If i create a simple application and then inserts the import in my file, in desktop works fine, but when export in xcode have the same errors.
I missing something reference in qt project? I added only arcgis_runtime_qml100_0_0 in CONFIG in .pro file
AntonioFiume
I hope i resolved with this update:
CONFIG += c++11 arcgis_runtime_qml100_0_0
QT += core gui opengl xml network positioning sensors
QT += qml quick
