Deployment problems with C++ sdk for 100.2 runtime windows using msvc2017_64
4964
11
07-27-2018 08:58 AM
ChristianNuckols
I'm having trouble deploying software from my  PC (on which I am developing our app) to our tablets (which are identical to our clients' systems).  Both use windows and the msvc compilers are up to date on both of the systems.  I know the tablets meet the system requirements for the runtime, because I've been able to build and deploy sample apps.    For instance, on the tablets, I can build and deploy the basic 'Display Map' sample if I comment out
import Esri.ArcGIS Extras 1.1
but if I don't, the app loads, but nothing is rendered:
c++ sdk qt deployment error
I understand that the extras require more .dll files.  I'm able to deploy apps with the Extras component (to any location on disk) on the development PC even if I explicitly set the runtime environment variable:
ArcGISRuntimeEnvironment::setInstallDirectory(QDir::currentPath());
I should note, that I am not actually using the extras component in my app.  Deployment of the sample apps was part of my  attempt to diagnose the issue, and I came across that problem.   To deploy my app on the development PC, I take the following steps:
1. Compile my release in QtCreator.  This stores the executable here:
C:\Users\cnuckols\ArcGIS\AppStudio\Apps\build-ULIP-Desktop_Qt_5_10_0_MSVC2017_64bit-Release
And the storage folder for my source code is:
C:\Users\cnuckols\ArcGIS\AppStudio\Apps\ULIP\
2. Move the executable to a folder on my desktop:
C:\Users\cnuckols\Desktop\Deployment2\ULIP.exe
3. Use the qt deployment tool for windows:
qt deployment tool windows 100.2 runtime
I should note that I've tried this with and without the angle option.
4. Copy the sdk runtime .dlls to the deployment folder:
core runtime dll release cpp sdk
Here are the contents of my deployment folder:
deployment folder contents
5. I run the app, and it works correctly.  However, when I move the deployment2 folder to the tablet it executes, but nothing is rendered:
I get no error messages and no warnings.
To further clarify, when I look at which dlls are being used by ULIP.exe in the tablet,  msvcp140.dll and vcruntime140.dll. are both listed (the ones contained in System32):
C:\WINDOWS\SYSTEM32\MSVCP140.dll
and
C:\WINDOWS\SYSTEM32\VCRUNTIME140.dll
-I have read the page on deploying the app:
Deploy your app—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
-I have read the system requirements page for the newer runtime:
System requirements for 100.3.0—ArcGIS Runtime SDK for Qt | ArcGIS for Developers
-I have read every geonet thread on deployment issues for the Qt SDK
-I am using the QtQuick Compiler
-I've been using the Qt windows deployment tool and have read the Qt page about using the tool:
Qt for Windows - Deployment | Qt 5.11
Thanks!
ChristianNuckols
For anyone coming across this thread, when you copy this folder into your deployment:
C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\windows\x64\qml
you need to look at
C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\windows\x64\qml\Esri\ArcGISExtras
and either append a version number to ArcGIS Extras to the copied subfolder or copy the appropriate Extras import library from the corresponding sample sdk
C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\samples\ArcGISRuntimeSDKQt_CppSamples\bin\qml\Esri\ArcGISExtras.1.1
Even if your app doesn't use this import. My app doesn't and this was the difference between it functioning on the deploy device or not.
JamesBallard1
Hi Christian Nuckols
   Thanks for the excellent troubleshooting. Can you see if the Extras folder is included in your deployment? It should be in the qml folder, like follows. It may be named just "ArcGISExtras", too. Please take a look.
Extras Deployment Path
That's the expected location for the Extras deployment.
ChristianNuckols
No I can't.  Should I be seeing a qml folder even if I'm using the QtQuick compiler?
ChristianNuckols
I should also note that I have this folder in my ArcGIS SDKs directory:
which has the same file structure, but doesn't use the version number.
JamesBallard1
You'll still need the qml folder in a deployed app, even with the QtQuick Compiler. You can grab that entire "C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\windows\x64\qml" folder and drop it into your deployment (the whole qml folder). Please let me know if that helps.
JamesBallard1
Christian Nuckols‌ a good example of a deployed Windows app is included with the setup. See "C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\samples\ArcGISRuntimeSDKQt_QMLSamples\bin". The "qml" folder structure should be similar to what you need for your deployed app.
ChristianNuckols
Thank you.  I tried adding the just the QML folder you linked to and got the same result.
The extras folder doesn't have version info, which was different from the qml folder in the esri samples:
C:\Program Files (x86)\ArcGIS SDKs\Qt100.2.1\sdk\samples\ArcGISRuntimeSDKQt_QMLSamples\bin\qml\Esri\ArcGISExtras.1.1
Also, should I be using the ArcGISRuntimeSDKQt_QMLSamples or ArcGISRuntimeSDKQt_CppSamples as a reference? (im using QML and cpp - have multiple .qml and multiple .cpp files)
Also I tried moving all of the api-ms-win*.dll files to my app, in addition to copying any missing files. (from both the QML samples and the cpp samples). In both cases, I got this as a result:
ChristianNuckols
James, I got the app to deploy by appending the version number. Thanks so much for your help!
JamesBallard1
Christian Nuckols‌, that's great news! Happy to help.
ChristianNuckols
you need to look at
