Crash in runtimecore.dll
2186
03-20-2019 04:28 AM
HenrikVatnar
Hi
I'm getting a strange crash in the arcgis qt sdk runtimecore.dll when running an application using a scene view.
It always exits with the following exception:
Exception thrown at 0x00007FFC781DA08D (runtimecore.dll) in test.exe: 0xC0000005: Access violation reading location 0x0000000000000008. (Not in the Main thread)
I can't be completely sure, but by trial and error I think I've narrowed it down to calling GraphicListModel::removeOne while at the same time doing zooming/panning.
I'm calling GraphicListModel::removeOne quite often(Main thread) because I'm trying to remove Graphics objects when they go outside of the sceneview extent.
Could I be doing something illegal when I try to remove graphics from the overlay? Is there a certain way it needs to be done?
Just for testing I've tried to avoid deleting the graphics(only call removeOne) but it still seems to crash. However if I just make the graphics invisible and don't remove them from the model it doesn't seem to crash(But leads to a "small" memory leak )
Anyone seen the same problem?
Based on the exception I guess it could be a missing nullptr check somewhere in the runtimecore? Or I might be doing something horribly wrong somewhere else.
I'm using: windows 10, arcgis qt sdk 100.4 and qt 5.12.0
LucasDanzinger
Esri Frequent Contributor
Are you deleting the Graphics? RemoveOne will remove it from the list but will not delete the object. If you are deleting the graphic after/while you remove it from the list model, I think you are likely hitting this bug, which is fixed in 100.5 - BUG-000117464: Modifying the graphics list and deleting the graphic..
HenrikVatnar
Thanks for the quick reply! Yeah it sounds like the same problem, but from
what I could see it seems to happen even if I avoid deleting the graphic.
I'm not in any rush so I'll wait for the 100.5 and see what happens. Thanks
again!
