Can callout data used with MapGraphicsView QT
1485
12-17-2020 04:43 AM
GirishchandraY
Hello Team,
Can you please tell us how to load call out data in MapGraphicsView QT.
As we are not using QML.
Tags (1)
by Anonymous User
Not applicable
Currently, there is now widget equivalent for the Callout class.
Having said that, the Callout is only a thin view of a CalloutData, which contains the text, image, and screen position of where it should be displayed.
You can access CalloutData by calling `CalloutData* MapGraphicsView::calloutData()`, and write your own widget -- the key being to display it on the screen at the location provided.
GirishchandraY
I don't see  callout widget .I do have data  for every location which I need to show over map view.
Can you suggest how display it Over MapGraphics View.
