ArcGIS Runtime Crash when using OpenStreetMap vector layer
2144
03-22-2021 02:03 PM
FrédéricSCHETTINI
Hi the Runtime team,
I would like to report the following bug
OpenStreetMap basemap or OpenStreetMap vector layer (custom style) causes mobile application to crash when set at higher scale.
The cause of the crash was analyzed by the AppStudio team and the crash is at the Runtime level.
To reproduce:
  • Create a web map with an OSM basemap in ArcGIS Online.
  • Use the MapViewer AppStudio template, set the APP property Map Query in Gallery id:YourWebMapItem
  • Build the APP (using the cloud based build)
  • Install and run the APP on your mobile.
  • Alternatively, you can use the AppStudio player on your mobile
  • Try multiple zoom in, pan around, etc.
  • The App will crash
Reproducible on Android 10.0
  • Apk built AppStudio Cloud based build
    • AppStudio Framework : 4.4.77
    • Runtime SDK 100.8
  • Or use AppStudio Player 5.0.9
    • AppStudio Framework : 5.0.126
    • Runtime SDK 100.10.0.3002
Please let me know if it is a not issue and there is a work around.
Looking forward to hearing from you.
Thank you
Frédéric
GuillaumeBelz
Thank you for your crash report. Your issue lookzs similar to a crash reported by iOS user https://community.esri.com/t5/arcgis-runtime-sdk-for-ios/esri-runtimecore-crashes-when-using-osm-vec.... This will be fixed in 100.11.
Guillaume
GuillaumeBelz
Guillaume
FrédéricSCHETTINI
Hi Guillaume,
Thanks for your fast response.
Indeed, the crash looks the same.
Do you know when 100.11 is going to be released?
Frédéric.
GuillaumeBelz
"ArcGIS Runtime 100.11, due to be released in April 2021" (source: https://www.esri.com/arcgis-blog/products/developers/announcements/welcome-to-arcgis-runtime-100-10/...
