Adding new records to a standalone table contained within a local geodatabase?
2564
5
05-31-2017 07:12 PM
_____
LucasDanzinger
Esri Frequent Contributor
Is your feature table loaded? Other feature tables used in layers probably implicitly get loaded by the layer being in the map, but the table would need to be explicitly loaded since nothing else would load it.
ft.loadStatusChanged.connect(function() {
            if (ft.loadStatus === Enums.LoadStatusLoaded) {
                console.log("loaded");
                console.log(ft.canAdd())
                console.log(ft.createFeature())
ft.load();
LucasDanzinger
can you just use the createFeature method? FeatureTable QML Type | ArcGIS for Developers
_____
LucasDanzinger
ft.load();
_____
LucasDanzinger
Is there any reason not to do this? Could it break in the future?
You should be able to continue using it. If it stops working, it would be a regression and not by design.
