Adding a drop down menu to the map
2097
05-26-2021 06:53 AM
FatmaAkdemir
Is there a way to enable user to see a drop down menu when he/she right clicks to the map? And when he selects one of the items in that menu, some action needs to be performed.
JaredCaccamo
Hello again @FatmaAkdemir ,
In that case you can use "mousePressed" with "RightButton" to catch the mouse events and "QMenu::exec" to open a context menu. Or if you don't want to use a menu, you could use "QPushButton" instead.
Documentation for C++:
https://developers.arcgis.com/qt/cpp/api-reference/esri-arcgisruntime-mapgraphicsview.html
https://doc.qt.io/qt-5/qmenu.html#exec-1
https://doc.qt.io/qt-5/qpushbutton.html
Sincerely,
Jared
JaredCaccamo
Hello @FatmaAkdemir,
Yes using a combination of the MapView and QtQuick.Controls you definitely could. You would need to listen for the MapView.onMouseClicked signal and then use mouse.x and mouse.y then use those to update the x and y of the QtQuick.Controls ComboBox(drop down menu) which can take a ListModel(list of items in that menu) then you can listen for the ComboBox.onActivated(int index) signal for the selection from that list and use the index to know which model from that list was selected and do whatever following action you would like.
Here is an example:
import QtQuick 2.6
import QtQuick.Controls 2.2
import QtQuick.Dialogs 1.2
import Esri.ArcGISRuntime 100.11
ApplicationWindow {
    width: 800
    height: 600
    title: "Example"
    property var myExModel : ["apple", "pie", "cherry", "pie"]
    // add a mapView component
    MapView {
        anchors.fill: parent
        // set focus to enable keyboard navigation
        focus: true
        // add a map to the mapview
        Map {
            // add the ArcGISStreets basemap to the map
            initBasemapStyle: Enums.BasemapStyleArcGISStreets
        onMouseClicked: {
            myComboBox.x = mouse.x;
            myComboBox.y = mouse.y;
            myComboBox.visible = true;
    ComboBox {
        model: myExModel
        visible: false
        onActivated: {
            myDialog.text = myExModel[index];
            visible = false;
            myDialog.open();
    MessageDialog {
Hope you find this helpful!
Sincerely,
Jared
FatmaAkdemir
Hi @JaredCaccamo ,
Thank you for the detailed answer. Unfortunately I am not using QML. Should I use QComboBox in this case? In fact I only need a pop-up button ("Delete") when user right clicks on a graphic. After user clicks on that button, graphic will be deleted from the map.
JaredCaccamo
Sincerely,
Jared
