Stop Python Toolbox aranging params alphabetically
3264
8
02-08-2017 09:13 AM
RajeshKulandaivelu
Is that really possible to control Python Toolbox from arranging the params alphabetically, at least the category?
DanPatterson_Retired
can you provide an example of what you are talking about?
RebeccaStrauch__GISP
Like Dan said, a little more info would be helpful....but the way I fool things that get sorted, for example, to get my python tools and scripts to show in the order I want, I add a preceeding number, e.g.
01MyFirstTool
02MySecondTool
or something like that.  Might not help you, but just in case...
RajeshKulandaivelu
Thanks Dan and Rebecca!
Rebecca,
Yes, I have numbered them but I really don't like that, still trying to find a way for it. Attached are the screen prints of what I was talking about. Pic1 is how I want the Param categories to be sorted (without numbers). If I remove the numbers - it looks the way Pic2 is.
Pic1
- Pic1
Pic2
Have you tried reordering them in the Parameters list...notice the up/down arrows on the right?  But keep in mind you may need to modify your script too.
(mine were in alpha order before...by choice)
RajeshKulandaivelu
Thanks, but the one you posted above works for ArcToolbox but not for Python Toolbox. In fact Python toolbox don't have this option, the params have to be managed in the script.
Rajesh
ok, sorry.  I don't mess with the Python toolbox yet, just ArcTool boxes and tools using Python scripts so I can create python addins.  I would have thought them to be the same.
edit: I guess this would be the help page for parameters in Python Toolbars Defining parameters in a Python toolbox—Help | ArcGIS Desktop  althought that still might not help you any.
Again... perhaps you can produce a visual of your issue since it is clear from the documentation that you have full control over the parameter order simply by ordering them logically when you create them ... here is the documentation link so an image and a script would help
Rebecca is correct... the link to working with Script Tools is in this link  There are subsections therein for other information
