Join Oracle table
1287
02-22-2018 12:08 PM
MelanieRosenberg2
I am trying to join an Oracle table to a feature class but have not found success yet...
Here is my code:
# Import arcpy moduleimport arcpyfrom arcpy import env #Set Variables parent = "Database Connections\\db.sde\\db.DBO.layer"child = "Database Connections\\db.sde\\db.DBO.layer2"codeList = ['SC21', 'SC22', 'SC23', 'SC24', 'SC25', 'SC26', '2C27', 'SC28', 'SC29', 'SC30', 'SC31', 'SC33', 'SC34', 'SC35', 'SC36', 'SC37']parentView = "layer"tableView = "connectionFees"table = "Database Connections/oracle.sde/oracleDB.oracleTable"if arcpy.Exists(child):    arcpy.Delete_management(child, "FeatureClass")#Make a feature layer in order to perform a selectionarcpy.MakeFeatureLayer_management(parent, parentView)#Select all features that match the codes from the code listfor code in codeList:    arcpy.SelectLayerByAttribute_management(parentView, "ADD_TO_SELECTION", "Code = '"+ code+"'")#Copy the selected featuresarcpy.CopyFeatures_management(parentView, child)#Make Query Layer of Oracle table since it does not contain an incrementing ID field
arcpy.MakeQueryLayer_management("Database Connections/db.sde", tableView, "SELECT   \n         field1,\n         field2,\n         field3,\n         SUM (amount) total\n    FROM layer\nGROUP BY field1\n", "field1", "", "", "")
#Join the gdb layer to the Connection Fees Table from oracle DB
arcpy
.JoinField_management(child, "field1", tableView, "field2")
I get a generic 999999 error.. Any thoughts?
Tags (4)
KimOllivier
Honored Contributor
Can you have another go at formatting the code? It is unreadable.
My strategy for the joinfield tool is Don't. Especially if it is a large table.
You will have trouble with joins across databases, and if it is in the same database, use a database join.
Instead I extract the data I need using a dictionary of tuples of the required fields using a SearchCursor dictionary comprehension.
Then add some fields to the target, or a copy and populate using an UpdateCursor.
This is always faster, reliable and works across databases. It does not need an index because a dictionary has a hash table underneath the hood.
To allow for missing values use the get function with a default of None.
