How to Set Data Source of a Layer In an MXD From SDE connection
2648
08-28-2017 09:40 PM
BehrouzHosseini
Can you please take a look at this example and let me know how to I can replace Data Source data of a layer in a saved mxd map (Fuse) to a layer called SDEElectric.DBO.Fuse which is in an enterprise geodatabase through database connection
I tried this code but it didnt work
import arcpy
mxd = arcpy.mapping.MapDocument(r"C:\GIS\Maps\Electric.mxd")
src =r"C:\Users\xxx\AppData\Roaming\ESRI\Desktop10.4\ArcCatalog\SDEElectric.sde\SDEElectric.DBO.Dataset\SDEElectric.DBO.Fuse"
df = arcpy.mapping.ListDataFrames(mxd, "")[0]
for lyr in arcpy.mapping.ListLayers(mxd, "", df):
 if lyr.name == "Fuse":
 lyr.replaceDataSource(src, "FILEGDB_WORKSPACE", "")
mxd.save()
del mxd
print "done"‍‍‍‍‍‍‍‍‍‍
Asrujit_SenGupta
Not a Python expert, but
Shouldn't the above reflect an Enterprise gdb, like below:
lyr.replaceDataSource(src, "SDE_WORKSPACE", "")
If the above doesn't help, share the errors you receive and that may also help someone to provide an answer....
BehrouzHosseini
Thanks Asrujit SenGupta
but still getting same error
Asrujit_SenGupta
What errors do you receive?
RebeccaStrauch__GISP
you may want to look at /blogs/myAlaskaGIS/2015/08/31/python-addin-for-data-inventory-and-broken-link-repair?sr=search&searc...‌ to see samples of how I view and replace sources in mxd.  It's based mainly on broken-links, so may not work for you, but just in case.
BehrouzHosseini
Thanks Rebecca, I already spend some time there but it was not really helpful as it mainly focus was on fixing broken links
