arcpy near analysis fails
6050
12
07-19-2017 06:48 AM
TinaOosterom1
When I run >>>arcpy.Near_analysis("ACN_Select","Derden","150 Meters", "NO_LOCATION", "NO_ANGLE","PLANAR") in the python window in ArcMap 10.4, it returns the correct numbers in the field NEAR_DIST.Results in ArcMap10.4
However, if I run the same in PyScripter:
import arcpy
arcpy.env.workspace = "C:\\Geoplay\\GLO\\Output.mdb"
if arcpy.CheckExtension("Spatial") == "Available":
    arcpy.AddMessage("Checking out Spatial")
else:
    arcpy.AddError("Unable to get spatial analyst extension")
    arcpy.AddMessage(arcpy.GetMessages(0))
    sys.exit(0)
ACN_Select = "C:\\Geoplay\\GLO\\GLO.gdb\\ACN_Select"
Derden = "C:\\Geoplay\\GLO\\GLO.gdb\\Derden"
#Near Analysis
arcpy.Near_analysis(ACN_Select,Derden,"150 Meters","NO_LOCATION","NO_ANGLE","PLANAR")
print "Ready!"
All the NEAR_FID and NEAR_DIST are -1.
Results from PyScripter
I tried creating layers and using those, but it didn't work. Also I tried setting the spatial ref with
spatRef = arcpy.Describe(ACN_in).spatialReference
but it did not change anything.
What am I missing?
TinaOosterom1
And because the more recent FC has lines near ACN_Select, even the distance limiter now works. Thanks so much, Dan.
JoshuaBixby
MVP Esteemed Contributor
What if you strip the script way down and run it directly from the Python interpreter, not through PyScripter?
import arcpy
#Near Analysis
TinaOosterom1
Hi Joshua,
Thanks for responding. It took me a while to find Python command line and how to copy the text, but I did. It ran very quickly indeed, but with the same results. It does makes the fields NEAR_FID and NEAR_DIST, but fills them both with "-1".
