arcpy.Delete_management not working on particular shpfiles.
1760
04-24-2018 12:57 PM
ShaneStevenson
Hi folks, I've been stuck on this for ages. Hopefully someone might have some tips. I have some code to delete a .shp file.
arcpy.env.workspace = "C:/check"
ws = arcpy.env.workspace
in_data = "Folklore.shp"
data_type = ""
arcpy.env.overwriteOutput = True
arcpy.Delete_management(in_data, data_type)
arcpy.Delete_management('Folklore.shp')
The shp file just won't delete. It seems to make it stop working but not delete. It is a points shp file. This code works fine if I delete a polygon shp file. So I don't think it is a problem with the code. Does anybody know of any particular issues with deleting certain types of shp files. There are no lock files. And ArcMAP and ArcCatalog are closed.
Thanks
Tags (1)
DanPatterson_Retired
from here... http://pro.arcgis.com/en/pro-app/tool-reference/data-management/delete.htm
import arcpy
of course the folder and the shape file must exist.  If there was a lock, then you would get an error.
You may need to refresh your views in Windows  to see changes and/or in whatever you are using to check to see if it is gone.
RandyBurton
Is it possible that the file's read-only attribute has been set?
