Zonal Statistics Crashes Randomly
9812
15
03-08-2011 01:09 PM
ColinLindeman
Aloha,
I am having issues with the Spatial Analyst tool ZonalStatisticsAsTable in that it appears to crash the script for no reason.
The input zones (66 individual zones) is a raster file of the same extent, projection and cell size as the value raster. Some runs the script will iterate anywhere from 1 to 32 times (it needs to go the full 72 iterations) before crashing.
I also notice that the output table of the last zonal stats isn't complete when it crashes, it gets about 15 records (of 66) into the statistics table.
Thanks for any feedback and suggestions!
-Colin
import string, datetime, arcpy
# set scratchworkspace... for desktop use, not ags use...
arcpy.env.scratchWorkspace = "C:/temp/scratch/"
# set overwrite outputs to true
arcpy.env.overwriteOutput = 1
# Variables...
netdcf_source_folder = "C:/mapservice_data/wrf/net_cdf_files/"
workspace_folder = "%SCRATCHWORKSPACE%/"
workspace_folder_filegdb = workspace_folder + "scratch.gdb/"
sde_workspace_d2p2 = "C:/mapservice_files/db_connections/connection.sde/"
InMemory_netcdf_raster = "InMemory_netCDF_File"
table_template = "C:/mapservice_data/WRF/wrf.gdb/wrf_table_template_rain"
in_zone_data = "C:/mapservice_data/WRF/wrf.gdb/wrf_zones"
model_runtime = '"' + str(datetime.datetime.now()) + '"'
# Variables based on the user input variable...
input_netcdf_file = netdcf_source_folder + "RAIN_vn10km.nc"
target_table = workspace_folder_filegdb + "wrf_rain_v2"
out_netcdf_table_view = "wrf_rain_table_view"
sde_table = sde_workspace_d2p2 + "D2P2.wrf_rain_v2"
time_table = []
# Check out the spatial analyst extension...
try:
 # Create a 'catch all' table for the statistics, this will be copied to SDE
 # Copy Rows...CopyRows_management (in_rows, out_table, {config_keyword})
 arcpy.CopyRows_management(table_template, target_table)
except:
 print "copy rows fail", arcpy.GetMessages()
try:
 # Create table of time slices from netcdf file...
 # MakeNetCDFTableView_md (in_netcdf_file, variable, out_table_view, {row_dimension}, {dimension_values}, {value_selection_method})
 arcpy.MakeNetCDFTableView_md(input_netcdf_file, "rain", out_netcdf_table_view, "time", "", "")
except:
 print "time slice table fail", arcpy.GetMessages()
try:
 # SearchCursor to get time values...
 # SearchCursor (dataset, {where_clause}, {spatial_reference}, {fields}, {sort_fields})
 rows = arcpy.SearchCursor(out_netcdf_table_view, "", "", "time", "")
 currentTime = ""
 for row in rows:
  if currentTime != row.time:
   currentTime = row.time
  time_table.append(row.time)
except:
 print "time_table fail", arcpy.GetMessages()
try:
 # Create a list of index numbers in the netcdf file to process...
 x = 0
 for time in time_table:
  if x < 10:
   y = "0" + str(x)#prefixes a "0" to numbers less than 10 to help in sorting.
  else:
   y = str(x)
  output_netcdf_raster = workspace_folder + "rain_" + y + ".img"
  zonalst_table = workspace_folder_filegdb + "rain_" + y + "_zonalst"
  time_slice_number = time
  try:
   # Make NetCDF Raster Layer...MakeNetCDFRasterLayer_md (in_netcdf_file, variable, x_dimension, y_dimension, out_raster_layer, {band_dimension}, {dimension_values}, {value_selection_method})
   arcpy.MakeNetCDFRasterLayer_md(input_netcdf_file, "rain", "longitude", "latitude", InMemory_netcdf_raster, "", time_slice_number, "BY_VALUE")
  except:
   print "Make NetCDF Raster Layer", time_slice_number, arcpy.GetMessages()
  try:
   # Copy Raster for zonal stats input...CopyRaster_management (in_raster, out_rasterdataset, {config_keyword}, {background_value}, {nodata_value}, {onebit_to_eightbit}, {colormap_to_RGB}, {pixel_type})
   arcpy.CopyRaster_management(InMemory_netcdf_raster, output_netcdf_raster,"","","","","","")
  except:
   print "Copy Raster", time_slice_number, arcpy.GetMessages()
  try:
   # Zonal Stats as table...ZonalStatisticsAsTable (in_zone_data, zone_field, in_value_raster, out_table, {ignore_nodata}, {statistics_type})
   arcpy.sa.ZonalStatisticsAsTable(in_zone_data, "D_NAME", output_netcdf_raster, zonalst_table, "DATA", "SUM")
  except:
   print "zonal stats as table", time_slice_number, arcpy.GetMessages()
  try:
   # Process: Add Field...AddField_management (in_table, field_name, field_type, {field_precision}, {field_scale}, {field_length}, {field_alias}, {field_is_nullable}, {field_is_required}, {field_domain})
   arcpy.AddField_management(zonalst_table, "INDEXSLICE", "SHORT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
  except:
   print "add field indexslice", index_slice_number, arcpy.GetMessages()
  try:
   # Process: Calculate Field...CalculateField_management (in_table, field, expression, {expression_type}, {code_block})
   expression = y
   arcpy.CalculateField_management(zonalst_table, "INDEXSLICE", expression, "PYTHON")
  except:
   print "calc field indexslice", index_slice_number, arcpy.GetMessages()
  try:
   arcpy.AddField_management(zonalst_table, "RUNTIME", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
  except:
   print "add field runtime", time_slice_number, arcpy.GetMessages()
  try:
   arcpy.CalculateField_management(zonalst_table, "RUNTIME", model_runtime, "PYTHON")
  except:
   print "calc field runtime", time_slice_number, arcpy.GetMessages()
##  try:
##   arcpy.AddField_management(zonalst_table, "TIMESLICE", "DATE", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
##  except:
##   print "add field timeslice", time_slice_number, arcpy.GetMessages()
##  try:
##   arcpy.CalculateField_management(zonalst_table, "TIMESLICE", time_slice_number, "PYTHON")
##  except:
##   print "calc field timeslice", time_slice_number, arcpy.GetMessages()
##  try:
##   arcpy.AddField_management(zonalst_table, "TIMESLICETXT", "TEXT", "", "", "", "", "NULLABLE", "NON_REQUIRED", "")
##  except:
##   print "add field timeslicetxt", time_slice_number, arcpy.GetMessages()
##  try:
##   arcpy.CalculateField_management(zonalst_table, "TIMESLICETXT", time_slice_number, "PYTHON")
##  except:
##   print "calc field timeslicetxt", time_slice_number, arcpy.GetMessages()
  try:
   # Process: Append...Append_management (inputs, target, {schema_type}, {field_mapping}, {subtype})
   arcpy.Append_management(zonalst_table, target_table, "NO_TEST", "", "")
  except:
   print "append", time_slice_number, arcpy.GetMessages()
  print y
  # add 1 to the counter
  x += 1
## #should add schema lock test here...
## TestSchemaLock (dataset)
## arcpy.TestSchemaLock()
## try:
##  # Copy the statistics table to SDE, overwriting the old table...
##  # Copy Rows...CopyRows_management (in_rows, out_table, {config_keyword})
##  arcpy.CopyRows_management(target_table, sde_table)
## except:
##  print "copyrows", time_slice_number, arcpy.GetMessages()
except:
 print "general failure", arcpy.GetMessages()
# Check in the spatial analyst extension...
arcpy.CheckInExtension("Spatial")
JamieKass
Has anyone from ESRI commented on this? I am have an identical problem while making a Select By Attribute followed by Zonal Statistics as Table, and my ArcMap crashes every time. This is disturbing because Zonal Statistics is a tool that many people use frequently. Is there a fix in the works?
ForrestStevens1
I'm experiencing the exact same problem with ArcGIS 10 SP5.  I can reproduce with multiple zonal sources, different folder/file and geodatabase outputs, both with background processing on and off and for polygon/raster zonal areas of varying sizes (50-1600 areas) and occurs when running as a standalone script or from within ArcMap.  It's extremely frustrating because the read/write locking only affects one of the machines I work on.
Executing: ZonalStatisticsAsTable admin_Union ADMINID KHM_popmap_admin003_v2b.tif C:\tmp\test2.dbf DATA SUM
Start Time: Sat Oct 13 10:44:14 2012
ERROR 999999: Error executing function.
Workspace or data source is read only.
Workspace or data source is read only. [The C:\tmp\ workspace is read only.]
ERROR 010067: Error in executing grid expression. Zonal statistics program failed
Failed to execute (ZonalStatisticsAsTable).
Failed at Sat Oct 13 10:44:28 2012 (Elapsed Time: 14.00 seconds)
It makes it through about half of the zonal areas and the fails apparently because it can't write to the table.  Any comments from ESRI would be useful?
ForrestStevens1
Well, I may have solved the problem in at least a subset of my use cases, as I haven't been able to duplicate this error after turning Microsoft Security Essentials "Real Time Protection" off.  I'm not running any other virus/spyware protection on the machine in question, but the "Real Time Protection" seems to consistently cause table writing functions of ArcGIS/Python Geoprocessing to fail with the read/write lock mentioned above.
I hope this might help others with the same problem!
ChrisSnyder
Honored Contributor
I am starting to see a reoccuring problem here!
http://forums.arcgis.com/threads/66584-repeated-AddField-operations-fails-in-10.1-works-in-10.0
Hope this issue is on ESRI's radar... And BTW it's not just Microsoft virus scan software... I've experienced this 1st on McAfee and now (after switching to Symantec since that initially fixed the problem), Symantec as well...
Symptom: ArcGIS tools randomly failing when run in a loop or in rapid repeated calls
ForrestStevens1
Indeed.  I don't have administrative access to disable the real-time protection on many of the machines I need to run these processes on.  But it seems like for repeated field or write operations that some type of buffering or delay should be default behavior for geoprocessing tools with the option of optimizing it for situations where no real-time monitoring is present.
GerardoArmendariz
Interestingly I was having the same problem for a while and after enabling garbage collection, my script now runs.
import gc
gc.enable()
