Write Russian field names to txt
2422
05-20-2014 03:09 AM
RebeccaWatson
I am trying to script a process to write out a list of datasets > feature classes > fields to a txt file but I am getting:
UnicodeEncodeError: 'ascii' codec can't encode characters in position 0-8: ordinal not in range(128) when the script gets to the bit to print out the field names. I think this is because some of the field names are in Russian cyrillic.
Can anyone advise how I get these Russian names to print to my text file? I have gathered that it is something to do with unicode but I'm finding the literature on unicode a bit daunting! My code is as follows:
... for fd in fdList: ...     arcpy.env.workspace = wksp+'/'+fd ...     fcList = arcpy.ListFeatureClasses() ...     txtFile.write (fd) ...     txtFile.write(os.linesep) ...     for fc in fcList: ...         arcpy.env.workspace = wksp+'/'+fd+'/'+fc ...         fields = arcpy.ListFields(arcpy.env.workspace) ...         txtFile.write(' '+fc) ...         txtFile.write(os.linesep) ...         for field in fields: ...             fieldname = field.name ...             txtFile.write(fieldname) ...             txtFile.write(os.linesep) ... #close file ... txtFile.close() ... print "done"
Many thanks,
RebeccaWatson
Thanks for your reply. I couldn't quite get that code to work it seemed to have a problem with something being a string, as follows:
>>> import io ... import arcpy ... from arcpy import env ... import os ... env.workspace = r"Database Connections\Direct Connect Editor User.sde" ... fdList = arcpy.ListDatasets() ... wksp = "Database Connections\Direct Connect Editor User.sde" ... arcpy.env.workspace = wksp ... with io.open(r"C:\Desktop\List.txt", "w", encoding="utf-8") as txtFile: ...     for fd in fdList: ...         arcpy.env.workspace = wksp+'/'+fd ...         fcList = arcpy.ListFeatureClasses() ...         txtFile.write (fd) ...         txtFile.write(os.linesep) ...         for fc in fcList: ...             arcpy.env.workspace = wksp+'/'+fd+'/'+fc ...             fields = arcpy.ListFields(arcpy.env.workspace) ...             txtFile.write(' '+fc) ...             txtFile.write(os.linesep) ...             for field in fields: ...                 txtFile.write(field.name) ...                 txtFile.write(os.linesep) ... #close file ... txtFile.close() ... print "done" ... Runtime error  Traceback (most recent call last):   File "<string>", line 19, in <module> TypeError: must be unicode, not str
But, it did lead me to this:
>>> import arcpy ... from arcpy import env ... import os ... env.workspace = r"Database Connections\Direct Connect Editor User.sde" ... fdList = arcpy.ListDatasets() ... wksp = "Database Connections\Direct Connect Editor User.sde" ... arcpy.env.workspace = wksp ... txtFile = open(r"C:\Desktop\List.txt","w") ... for fd in fdList: ...     arcpy.env.workspace = wksp+'/'+fd ...     fcList = arcpy.ListFeatureClasses() ...     txtFile.write (fd) ...     txtFile.write(os.linesep) ...     for fc in fcList: ...         arcpy.env.workspace = wksp+'/'+fd+'/'+fc ...         fields = arcpy.ListFields(arcpy.env.workspace) ...         txtFile.write(' '+fc) ...         txtFile.write(os.linesep) ...         for field in fields: ...             fieldname = field.name.encode("utf-8") ...             txtFile.write(fieldname) ...             txtFile.write(os.linesep) ... #close file ... txtFile.close() ... print "done"
There are a lot of results to look through and check, but it seems to have done the trick.
I would be interested if you could let me know why you think it doesn't work the other way.
Thanks for your help
JasonScheirer
Esri Alum
Could you paste the full traceback?
Try this:
import io
with io.open(myfile, "w", encoding="utf-8") as txtFile:
    for fd in fdList:
        txtFile.write(fd)
        for fc in fcList:
            txtFile.write(u' '+fc)
    print "done"
RebeccaWatson
