Write Blob field via Python?
2945
09-13-2011 03:45 PM
LewLadd
Hi Guys,
    I have a feature class with a blob field designed to hold images uploaded by users.
    Is it possible to populate the blob field via a python based service?
Lew.
StacyRendall1
Hmmm... Just found this post which says "ArcPy doesn't support reading or writing blob fields at 10.0."
I have never used a blob field before (so I'm not sure if it can do other fancy stuff as well), but can you store the file path as a string? You can definitely do that in Python - check out UpdateCursor.
LewLadd
Hi Stacy,
    Thanks for taking the time to reply.
    I wrote a quick test and trying to update with:
      newRow["myBlob"] = someBlob
does fail as you predicted.
So I'm using a column 'blobPath' and writing the blob to the path via a C# based fileUploader.
Thanks again,
Lew.
GarrettMoeller
Isn't it possible now?
JamesCrandall
MVP Alum
