Why am I having another "Select" issue using a variable?
4429
11
01-22-2020 04:17 PM
Mark_Hotz
I recently came to this forum with the virtually the same question, but now I'm using an "AND" instead of an "OR".  For the life of me I just cannot get this to work, and I don't know why.  The help I received for my last issue resolved my problem perfectly.  But now my query is only slightly more complex and it just won't go...so I'm wondering if a 2nd pair of eyes will help in my case.
It seems that I can do this when I hard code everything, but as soon as I try and use a variable it crashes with a very non-descript error message (e.g. Invalid Expression).
I have used 6 different expressions (listed and numbered below), and only expression2 and expression6 don't work...and these are the ones I need to work as this code is going to be transplanted into my main Python script once it's functioning.
expression1 is what works now after the help I received here...but I thought I could easily get the AND operator working because I now have the code working with an "OR" operator.  That didn't happen LOL.  Ideally, I would like to use the "AND" Boolean operator in this case (e.g. DateTime_2 = x and MMSI = y)...but I continue to struggle with this.
I try to keep my code very simple so it's easy for me to debug...and for the most part I'm able to do this (I'll continue to do this until I get better at Python scripting of course).  Can anyone see my errors?  Why can I not use expression2 or expression6?  I thought expression2 was almost an exact replica of expression1, but I guess not.
I use the exact same variable and value "record11" by itself in another script and it's fine...so I'm confident this isn't (by itself) the issue.
The query I would like to use would be similar to: DateTime_2 = fme_name_1b and MMSI = record11
import arcpy
year_1 = "2019"
month_1 = "01"
Q2_A = "201901"
record11 = 316003484
fme_name_1b = ((year_1) + (month_1)) #fme_name_1b now = 201901
print ("")
print ("fme_name_1b = " + str(fme_name_1b))
fc1 = r'F:\ArcGIS_Pro_Projects\AIS\AIS_Data\AIS_Data.gdb\TEST_AIS_Data'
#expression1 = ("DateTime_2 = '" + str(Q2_A) + "' or DateTime_2 = '" + str(Q2_B) + "' or DateTime_2 = '" + str(Q2_C) + "'") # WORKS PERFECTLY
#expression2 = ("DateTime_2 = '" + str(fme_name_1b) + "' and MMSI = '" + str(record11) + "'")  # DOES NOT WORK
#expression3 = ("DateTime_2 = '201907' And MMSI = 316012834") # WORKS PERFECTLY
#expression4 = ("DateTime_2 = '" + str(Q2_D) + "'") # WORKS PERFECTLY
expression5 = ("MMSI = 316003484") # WORKS PERFECTLY
#expression6 = ("MMSI = '" + str(record11) + "'") # DOES NOT WORK
print ("")
print (expression5)
print ("")
print ("Selecting records in fc1 that correspond to MMSI found in Summary Table")
SelectResult = arcpy.SelectLayerByAttribute_management((fc1), "NEW_SELECTION", (expression5))#Select records in feature class based on unique identifier (MMSI)
CountTotal = arcpy.GetCount_management((fc1))
CountResult = arcpy.GetCount_management(SelectResult)
print ("")
print (str(CountResult) + " Of " + str(CountTotal) + " Records Selected")‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thank you
JoshuaBixby
MVP Esteemed Contributor
I can't agree with Dan more, learn the Python mini-format language.  The bulk of your issue seems to be around data types and evaluating them within SQL strings, and the Python mini-format language allows you to focus on the structure of the string and not casting data types to string.
Mark_Hotz
Query Resolved:
I now have the script working.  What ultimately worked was:
expression7 = ("MMSI = " + str(record11))
Removing the quotes from the variable was indeed what it took, but because I'm using the + symbol it kept balking until I made it a string (go figure).  So the Select Attributes does work now in spite of the fact that my variable is a string that contains a number, or the fact that this variable is used to query the MMSI field that is a double data type...and because of this one small hurdle am now able to add it to the larger query:
expression2 = ("DateTime_2 = '" + str(YearMonth) + "' and MMSI = " + str(record11))
printing each step
YearMonth = 201901
expression2 = DateTime_2 = '201901' and MMSI = 316003484
Selecting records in fc1 based on expression
11 Of 75 Records Selected
I then tested this manually in ArcGIS Pro and I also end up with 11 of 75 records selected.  This portion of the script will now be added to the main program where it will query AIS data once per month that contains approximately 10-20 million records, filtered to 10%, and then published to Portal where heat maps of vessel traffic can be created.
Thanks for all of your help...the pointers I got here are all keepers and I will be reviewing all of this and doing a lot more reading :-).
