Where Expression
4138
09-26-2014 08:48 AM
PamFoster
Hi-
I'm trying to label a field using an expression.
I want the attribute to be labeled with field x except when field x equals "other" than I want it to be labeled with field y.
I don't know how to write the code/expression.
Any help would be appreciated, thanks!
Kait
JakeSkinner
Esri Esteemed Contributor
Hi Kaitlyn,
Here is an example on how to do this using the Python parser:
def FindLabel ([FIELDX], [FIELDY] ):
  if  [FIELDX] == 'other':
    return [FIELDY]
  else:
    return [FIELDX]
Below is a screen shot of the Label Expression dialog:
JakeSkinner
Hi Kaitlyn,
    return [FIELDY]
  else:
    return [FIELDX]
PamFoster
Thanks! That worked!
