When to use a geoprocessing tool or an update cursor?
2803
5
08-14-2023 10:19 AM
clt_cabq
One of my data processing steps is to apply a function to a field that updates the field contents to standardized values. I can accomplish this using either the Calculate Field tool or use an update cursor. The latter is roughly 5 seconds faster (12 vs 17 seconds) on a table with 142k records.
Is there a best practice or rule of thumb when deciding which approach to use? What are the advantages or disadvantages of either case in this situation? I also wonder if the Calculate Field tool is running an update cursor sort of behind the scenes.
DanPatterson
Keep it Simple S....
is the guiding principle, use
Calculate Field (Data Management)—ArcGIS Pro | Documentation
the tool goes to arcobjects as does the update cursor
(code can be followed in the following paths
  • C:\....install folder ...\Resources\ArcToolBox\toolboxes
  • C:\....install folder ...\Resources\ArcToolBox\Scripts
  • C:\....install folder ...\Resources\ArcPy\arcpy
A lot of condition checking goes on before the data even goes to a cursor... if you know absolutely that the data meets all the conditions and you will be the only one using the script without providing all the checks... then use a cursor and save you that huge 5 seconds.  That 5 seconds would be better spent sipping coffee and not worrying about whether you got everything right.
... sort of retired...
clt_cabq
Thanks Dan, my impression was that they are pretty equivalent but wasn't sure if there are other impacts to memory usage and such. And yeah, 5 seconds is nothing, that could just be network activity.
by Anonymous User
Not applicable
If I am only working on/updating one field only, I'd consider the calculate field method. If I wanted to use arcade, I'd use calculate field. If there is more than one field needed or I am updating more than one field, or I need to manipulate the data in some way, or the code_block would require python, I'd skip the hassle of trying to get the fields, tabs, and string formatting correctly and just use a cursor. I remember the cursor syntax a lot better too so it usually wins out.
clt_cabq
Thanks, this makes sense to me - in this particular use case I'm updating just one field. I have others though where I manipulate the values of several fields using an update cursor, much easier to do in the latter instance than with the field calculator.
AlfredBaldenweck
MVP Frequent Contributor
If you're working on versioned data in an enterprise GDB, it's a lot easier to calculate field than do an update cursor.
