What is the correct way to use measureOnLine attribute for polyline?
3351
10-27-2018 11:53 PM
CharithKarandana
I created a polyline myself and testing the measureOnLine attribute to use it in another script which goes with real data. "polyline.measureOnLine((x, y))" doesn't work ("I'm pretty much sure the point (x,y) is on the polyline. The funny thing is
"polyline.measureOnLine(polyline.positionAlongLine(length))" works (Although there is no use of such). So I believe there is something is missing form me. Can anyone help me to overcome this?
DanPatterson_Retired
Polyline—ArcPy classes | ArcGIS Desktop
measureOnLine (in_point, {use_percentage})
in_point has to be a point object and use_percentage is a boolean.
Your 'ValueError' is because you didn't provide the required object
So you need to make a point or use a point from some other object
ie arcpy.Point(x, y)
where x, y are coordinates.
Point—ArcPy classes | ArcGIS Desktop
You need to explore the arcpy section of the help to piece the useage together
CharithKarandana
One thing to add, I just found the 'queryPointAndDistance' brings the same error! It's called 'ValueError'
CharithKarandana
Thanks for your response and I'm sorry to say I tried both these. It didn't work.
This was the line in my script which returned with the ffollowing error
polyline.queryPointAndDistance(startPoint)
File "C:\Program Files (x86)\ArcGIS\Desktop10.5\ArcPy\arcpy\arcobjects\arcobjects.py", line 791, in queryPointAndDistance
return convertArcObjectToPythonObject(self._arc_object.QueryPointAndDistance(*gp_fixargs((in_point, use_percentage))))
ValueError: [422809.7100999998, 845539.4996000007]
Same happens to the measureOnLine.
CharithKarandana
I was wrong. Your reply helped me to understand my error. Thank you very much.
