Using python delete old tables with date and time in table's name
5611
14
08-07-2019 11:00 PM
SheikhHafiz1
I have been using ArcGIS 10.3.1.
I have a list of tables in an enterprise geodatabase with date and time in the table name. Every day one table is created, as an outcome of some geoprocessing tasks with the date and time in the table’s name when the table is created.
Naming format of the tables are FHRT_YYYYmmdd_HHMMSS
Like
  1. FHRT_20190808_071015 (this table is created on 08 August 2019 at 07:10:15)
  2. FHRT_20190807_071218 (this table is created on 07 August 2019 at 07:12:18)
  3. FHRT_20190806_071119
  4. FHRT_20190805_071913
  5. FHRT_20190804_071418
  6. FHRT_20190803_071014
  7. FHRT_20190802_070815
etc.
I want to create a python script that will keep the latest 3 tables (in this example FHRT_20190808_071015, FHRT_20190807_071218 and FHRT_20190806_071119) and delete the rest with similar name format. The geodatabase may have other tables with other name format (cadastre, property etc.), I do not want to touch those.
Being new in Python I do not know how I would create the script that will specify the dates.
I mean how will I instruct the script to keep the 3 tables that have the latest dates and delete the older tables?
What module do i need to import and what would be the statement?
Thank you in advance.
Regards,
Hafiz
JoshuaBixby
MVP Esteemed Contributor
It seems you are very new to Python/ArcPy. If so, you will need to learn to walk before you try running (not that your question is all that complicated).
I recommend starting with learning how to list feature classes in a workspace.  Once you that process, then you can start manipulating the list to find the 3 most recent tables.   I personally prefer using Walk—Help | ArcGIS Desktop since it mimics native Python file system functionality.
In terms of finding the most recent 3 tables based on datetimes in table names, the structure of your naming convention should allow you to not bother with actually converting the date string to Python datetime.
>>> import datetime
>>> fhrt_tables = [  # List of tables starting with FHRT
...     "FHRT_20190808_071015",
...     "FHRT_20190807_071218",
...     "FHRT_20190806_071119",
...     "FHRT_20190805_071913",
...     "FHRT_20190804_071418",
...     "FHRT_20190803_071014",
...     "FHRT_20190802_070815"
>>> recent_three = sorted(fhrt_tables, reverse=True)[:3]
>>> recent_three
['FHRT_20190808_071015', 'FHRT_20190807_071218', 'FHRT_20190806_071119']
SheikhHafiz1
Hi Joshua,
Thank you for your quick help.
I tried to delete old three tables and I created the script like the following
import arcpy
arcpy.env.workspace = "\\\\main\\gis_data\\FHRITest.gdb"
Tables = arcpy.ListTables("FHRT_20*")
print(Tables)
old_three = sorted(Tables, reverse=False)[:3]
print ("\n" + "Following are the tables:" + "\n")
print (old_three)
arcpy.Delete_management(old_three, "table")
and the script is throwing the following error
[u'FHRT_20190805_161001', u'FHRT_20190805_161142', u'FHRT_20190805_162929', u'FHRT_20190805_163204', u'FHRT_20190805_163527']
[u'FHRT_20190805_161001', u'FHRT_20190805_161142', u'FHRT_20190805_162929']
File "N:\Scripts\DeleteOldTables.py", line 11, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\ArcPy\arcpy\management.py", line 4092, in Delete
raise e
RuntimeError: Object: Error in executing tool
It must be very easy for you to resolve the issue.
DanPatterson_Retired
You will have to delete them one at a time since you can only delete multiple data elements since ArcGIS Pro 2.4.  You will have to use a for loop in your code
Delete—Data Management toolbox | ArcGIS Desktop
Starting in ArcGIS Pro 2.4, the Delete tool can be used to delete multiple items.
MichaelVolz
Dan:
If the code sample was formatted to run with python 3.x that is bundled with Pro 2.4, a list of items would be able to be deleted all at once instead of in a loop?  I would guess this type of capability would never be ported to python 2.x that is bundled with ArcMap as python 2.x and ArcMap, although not retired, are in the process of being retired over the next 2-5 years?
Michael, the last line in the post is copied from the help suggesting that the ability to delete multiple elements began with Pro 2.4.  Esri doesn't backport enhancements to previous versions, and the ArcMap help for 10.7 would have to be consulted to see if the capability also exists there.  Generally arcmap and pro keep in step, but I don't use arcmap.
Sehafiz
Thank you Dan.
I created the following script to delete one table from an SDE database connection. When I change the workspace path to a local file geodatabase it works fine but the sde database connection doesn't work.
import arcpy
Delete_succeeded = "true"
arcpy.env.workspace = "C:\\Users\\app_arcgis\\AppData\\Roaming\\ESRI\\Desktop10.3\\ArcCatalog\\VMAPPDBUAT_GISDEL_GIS.sde"
print(Tables)
old_one = sorted(Tables, reverse=False)[:1]
print ("\n")
for one in old_one:
print(one)
arcpy.Delete_management(one)
and I am getting the following error
File "C:\Scripts\DeleteOldTable.py", line 13, in <module>
NameError: name 'one' is not defined
Could you please help me to resolve?
/blogs/dan_patterson/2016/08/14/script-formatting
would help with line numbers, since it is failing on line 13, and I can only see 9.
Sehafiz
import arcpy
print(Tables)
print ("\n")
for one in old_one:
    print(one)
Above is the code and the error is as follows
  File "C:\FishHealth\Scripts\DeleteOldTable.py", line 13, in <module>
Thank you for your help Dan.
print(Tables)
# change to....
print("{} tables found\n{}".format(len(Tables), Tables))
just to make sure there is something.  And if there is and if you want to delete, move it up to line 12 and indent by 4 spaces
