Using Lists with arcpy.da.UpdateCursor
9622
16
07-13-2018 07:56 AM
deleted-user-_7x2iiEJ9SpB
I am trying to use arcpy.da.UpdateCursor to find and replace old values in a field with new values.  I have made it work but I will ended up with an ridiculously lard if\elif statement (notice below that I stopped after the first 2 items in the list).  I would like to avoid this by iterating through both list to update the field.  I have tried without any luck.  Any suggestions?  Code is attached.
The issue i'm running into is that I don't want it to print 100 times "not in list."  I just want it to total up the number of times other values are found.
JoeBorgione
How about setting a counter variable?
counter = 0
for row in cursor:
        if if row[0] not in LCStatus.keys():
            # print error message and keep original value
            #print "{} not in list".format(row[0])
            counter +=1
        else: # update value
            row[0] = LCStatus[row[0]]
            cursor.updateRow(row)
print '{} rows not in list...'.format(counter)‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
It seems there may be values in the records that are not in your list.  That is good information to offer up earlier in the thread since it will change the structure of the code.
Using my original code suggestion, I believe the following will work for you:
import arcpy
fc = r'G:\pworks\assetmanagement\Local Gov Info Model\Wastewater\Inputs\Valve_Schema.gdb\SControlValve'
LifeCycleStatus1 = ["ABN", "ACT","AB","CHGORD","DEM","INA","OTH","PRP","RMV","UNK","FV", "FD"]
LifeCycleStatus2 = ["Abandoned","Active","As Built","Change Order","Demolished","Inactive","Other","Proposed","Removed","Unknown","Field Verification Required","Future Development"]
try:
    cursor = arcpy.da.UpdateCursor(fc, ["LIFECYCLESTATUS"])
    cnt = 0
    for row in cursor:
        if row[0] in LifeCycleStatus1:
            row[0] = LifeCycleStatus2[LifeCycleStatus1.index(row[0])]
        else:
            cnt += 1
    del row
    del cursor
    print("{} records didn't have Life Cycle Status values in list".format(cnt))
except RuntimeError:
    pass‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoeBorgione
Joshua Bixby‌ - where does 'i' come from in line 18?
JoshuaBixby
My bad, I have corrected it from "i" to "1".
Joshua Bixby‌ it wasn't my original goal to print out the values until I realized how many we had that were missing\wrong.
RandyBurton
Something like this should give a listing with a count of the values in the LIFECYCLESTATUS field:
import arcpy
field = 'LIFECYCLESTATUS'
d = {} # new dictionary
with arcpy.da.SearchCursor(fc, (field)) as rows:
    for row in rows:
        if row[0] not in d:
            d[row[0]] = 1
        else:
            d[row[0]] += 1
for k, v in d.iteritems():
    print k, v
