Using GetParameterAsText() with Cursor.
3825
8
11-11-2014 07:51 AM
anTonialcaraz
Hi, I'm trying to use the GetParameterAsText() for user input.
When I use a value instead, it works fine but not with GetParameterAsText()
Any help will be greatly appreciate.
               NOT WORKING        WORKING
AreaFilter = arcpy.GetParameterAsText(0)
cur = arcpy.UpdateCursor(outFeatureAREA)
for row in cur:
    if row.F_AREA <= AreaFilter:
        cur.deleteRow(row)
        cur.updateRow(row)
del row
del cur
JakeSkinner
Esri Esteemed Contributor
Hi Alcaraz,
Try using the following:
AreaFilter = float(arcpy.GetParameterAsText(0))
anTonialcaraz
Thanks Jake. Yes, I had already try that. I don't quite understand why it's not working.
Cheers
JakeSkinner
Are you running the tool as a script within ArcMap?  If so, what is the Data Type you have specified for this parameter?  Try specifying this as a 'Double'.  Ex:
anTonialcaraz
Hi, I was being too optimistic.
Here is the whole code:
import arcpy
import string
import math
from arcpy import env
arcpy.env.overwriteOutput=True
from arcpy.sa import *
arcpy.CheckOutExtension("Spatial")
# Set workspace location, extent and variables
INWorkspace = r"D:\PROGRAMMES\LFP_Source_Rocks\ArcGIS\00_LFP_GLOBAL\00_LFP_GLOBAL_Python\WORK_TEST_space\ISLAND_Effect\INPUT.gdb"
arcpy.env.extent = arcpy.Extent(-180.0, -90.0, 180.0, 90.0)
inFeature = INWorkspace + "\\" + "G_SL_HiStand_20M_J_Tith_m2_0"
outFeature = INWorkspace + "\\" + "HiStand_polygon"
outFeatureAREA = INWorkspace + "\\" + "HiStand_polygonAREA"
# Convert polyline feature to polygon
arcpy.FeatureToPolygon_management(inFeature, outFeature, "","NO_ATTRIBUTES", "")
# Calculate area in KM2
arcpy.CalculateAreas_stats(outFeature, outFeatureAREA)
Expr = "(!F_AREA!) / 1000000"
arcpy.CalculateField_management(outFeatureAREA,"F_AREA",Expr,"PYTHON")
# Filter by Area
for row in cur:
        cur.deleteRow(row)
        cur.updateRow(row)
del row
del cur
If I run the script up to "# Filter by Area" it will create a Polygon Feature Class (HiStand_polygonAREA) with a field called "F_Area" holding all area values.
If I then run the script only from "# Filter by Area" with "HiStand_polygonAREA" as the input feature class (outFeatureAREA) it works.
If I run the whole script at once it still produces the output required (HiStand_polygonAREA) but it doesn't perform anything within the cursor part, for example, deleting those rows <= than 1000; and I get this:
So, I'm lost now.
Luis_ÁngelPascual_Camino
Hi again.
It looks like the value entered in the script execution dialog window (where you have written the parameter declared into scripts parameters) is a literal like "HiStand_polygon" and it cannot be converted to float.Have you entered a number in this parameter at execution time?
Is it the only one or do you have more parameters? You know the order is important, the first parameter declared has position number 0, the second has 1, and so on...
I can't think anything else, well, only one comment: why don't you get the parameter at the beginning of the script?
Maybe you can isolate the problem. I mean that there are others function calls along the code and the script can override the "parameter" value with the last one executed. (I don't know exactly, it's only an intuition).
Good luck!
Luis
anTonialcaraz
Thanks a lot Luis.
I put the parameter at the beginning of the script (as I normally do actually) and now IT WORKS!
That "rule" seems obviously to be important and I'm sure there is an explanation for it...
Many thanks!
Hi Alcaraz.
What about this?
AreaFilter = arcpy.GetParameter(0)
#If you want to convert to float:
AreaFilter = float(arcpy.GetParameter(0))
I used this code in v9.3:
import sys
AreaFilter = sys.argv[1] # The first argument has index number 1
I hope it helps. Good luck!
Luis
anTonialcaraz
Gracias Luis,
Just found that what was going on:
The "AreaFilter" field data type on the attribute table was "Double"; that matches the data type for the parameter within the tool properties dialogue box (see image) (there is no "Float" option).
Well, apparently python doesn't like that. I created a new "Float" Area field and used it in the script instead of AreaFilter. Now it works.
I think that the fact that there is no "Float" option in the Data Type python tool may lead to confusion.
Cheers
