Using code block in field calculator
10342
11
03-04-2019 06:24 AM
Thomvan_Oijen
Hello Community,
I'm completely at a lost here. I have tried all possible combinations and was trying to figure out how to get this to work but it just doesn't work for me.
The thing I am trying to accomplish is the following:
I have 5 fields with a or b answers (1 or 0) and 5 fields with the correct solution. (also 1 or 0).
Q1-5 and A1-5.
I also have 5 fields with a Weight
W1-5.
I am trying to find a floating value of 0-1 based on the answer. This goes in the field Betrouwbaarheid
This is what I have so far, which is to you very clearly incorrect. But I have tried a lot of different types of formatting without avail.
Note: It's updated!
Expression:
calc(!Q1!, !Q2!, !Q3!, !Q4!, !Q5!, !A1!, !A2!, !A3!, !A4!, !A5!, !W1!, !W2!, !W3!, !W4!, !W5)
Code block:
def calc(Q1, Q2, Q3, Q4, Q5, A1, A2, A3, A4, A5, W1, W2, W3, W4, W5):
    if Q1 == A1:
        c1 = 1
    else:
        c1 = 0
    if Q2 == A2:
        c2 = 1
    else:
        c2 = 0
    if Q3 == A3:
        c3 = 1
    else:
        c3 = 0
    if Q4 == A4:
        c4 = 1
    else:
        c4 = 0
    if Q5 == A5:
        c5 = 1
    else:
        c5 = 0
    betr = (c1 * W1 + c2 * W2 + c3 * W3 + c4 * W4 + c5 * W5) / (W1 + W2 + W3 + W4 + W5)
    return betr‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
Thanks to the people below a part was resolved. My new code gives no syntax errors.
However, i still get an error when trying to do a field calculation.
 ERROR 000539:   File "<expression>", line 1
    calc(, , , , , , , , , , , , , , )
SyntaxError: invalid syntax
 Failed to execute (CalculateField).
I hope anyone can shed me some light into how this codeblock programming works. It's a complete and utter mystery to me.
DanPatterson_Retired
/blogs/dan_patterson/2016/08/14/script-formatting
so line numbers can be referred to
The code block shouldn't contain the field names in the exclamation marks.  They should reference variables.
The expression lines makes reference to those.  So the code block with a python parser goes in that section and the expression in its line.  In the example below  !Field1! is now linked to 'a' etc
def fake_def(a,b,c):
    """fake function"""
    d = a + b + c
    return d
# expression
fake_def(!Field1!, !Field2!, !Field3!)
VinceAngelo
Esri Esteemed Contributor
You haven't defined the Python variables Q1/A1/W1/Q2/A2/W2/Q3/A3/W3/Q4/A4/W4/Q5/A5/W5 (by adding them to parameter list?) and don't use Python syntax to reference the W? variables in the code block.
The expression should look like
computeFn(!var1!,...!varN!)
And the code block like
def computeFn(var1,...varN):
     return var1 * ...
- V
    """fake function"""
    d = a + b + c
    return d
# expression
Thomvan_Oijen
Thank you! You know this is not explained anywhere.
I'll update on a next post as it's not quite resolved yet.
Thomvan_Oijen
Thanks to the people above I finally know how to properly use fields in the code block.
Unfortunately I still get an error message. This time it gives the following error:
can you copy your function and your expression.
if your function was...
def calc(,,,,,,,,)
and your expression was
calc(,,,,,,)
it will fail miserably since you didn't supply the field names to the expression, nor did you provide variable names to the function
Thomvan_Oijen
Thanks dan,
The used expression and code is in my opening post. I updated it.
It has the same amount of variabels in the code as I have fields in the expression. (so same amount of ,)
!W5!   you have !W5
VinceAngelo
Going back and editing the initial post is required in GIS SE, but it's confusing here, where there is no way to distinguish comments  from answers.  Far better to post edited code as a reply to the original post, so that your current code is provided as a snapshot in time.
- V
ScottDrzyzga
Are all your weight fields (your Ws) stored using numeric data types?  If any (or all) of your weight fields is (are) defined as text strings, then trying to multiply by a string will cause the calculation to fail.
GIS professional and map nerd | Outdoor enthusiast | Remote Pilot (USA and Canada)
