Use user input in Combo Box to perform a Definition Query
2395
7
06-06-2013 11:07 AM
danielchaboya
I'm nut sure which function (i'm assuming onEnter) to use and how to write the code to be able to get a users input ( type it in the text box of the combo box), hit enter and have it performe a definition query on a layer.  I can accomplish this by using a search cursor and populating the combo box with the returned values, but i prefer no to do this as returns a rather large list.  Any thoughts?
JamesCrandall
I've tried this ....
def onEnter(self):         mxd = arcpy.mapping.MapDocument("CURRENT")         df = mxd.activeDataFrame                  Lots = arcpy.mapping.ListLayers(mxd, "Lots", df)         plan = SearchPlanNumber_1.value         query = '\"PlanNumber\" = \'' + str(plan) + '\''                  print plan         print query                  arcpy.SelectLayerByAttribute_management(Lots, "NEW_SELECTION", query)         df.zoomToSelectedFeatures          for lyr in arcpy.mapping.ListLayers(mxd, "", df):             if lyr.name == "LotSelection":                 lyr.definitionQuery = '"PlanNumber" = \'' + plan + "'"                          arcpy.RefreshActiveView()         arcpy.RefreshTOC()
If I comment out the SelectByAttribute and df.zoomToSelectedFeatures, I can manipulate the definition query.  However,  It looks like there is something wrong with the where clause in the SelectByAttribute tool.  It fails with the following error ...
Traceback (most recent call last):   File "C:\Users\dchaboya\AppData\Local\ESRI\Desktop10.1\AssemblyCache\{7657B98A-A37F-CA5E-A8E1-C6CEF093100B}\SearchPlanNumber_addin.py", line 32, in onEnter     arcpy.SelectLayerByAttribute_management(Lots, "NEW_SELECTION", query)   File "C:\Program Files\ArcGIS\Desktop10.1\arcpy\arcpy\management.py", line 6435, in SelectLayerByAttribute     raise e RuntimeError: Object: Error in executing tool
Both print statements are returning the values that i'm expecting.   For example,  if I type in VIP88129 in the combo box, the python window in ArcMap returns VIP88129.  Also, it returns the query with the syntanx that I believe should work in the SelectByAttribute tool, which is "PlanNumber" = 'VIP88129'.   Not sure what's going on there.
I think your error when attempting to execute the SelectByAttributes is because of the way you are setting the "Lots" layer.  If you say the definition query is working correctly, then use the same process to set the layer:
Instead of:
Use:
for lyr in arcpy.mapping.ListLayers(mxd, "", df):     if lyr.name == "Lots":         lyr.definitionQuery = '"PlanNumber" = \'' + plan + "'"         arcpy.SelectLayerByAttribute_management(Lots, "NEW_SELECTION", query)
markdenil
I have used onEditChange for capturing the type-in input
and then used an OK button to start the processing.
danielchaboya
def onEnter(self):
        print plan
        print query
        arcpy.RefreshTOC()
    raise e
markdenil
I would suggest setting a queryVal variable to some default value ("") at the start of the toolbar script.
Next, in the onEditChange event handler for the combo box,
declare the queryVal variable as global, and set queryVal to the combobox text.
    def onEditChange(self, text):
        global queryVal
        queryVal = str(text)[\CODE]
Now the queryVal vaiable is available for use in the onClick handler
for an Apply button.
This is where you would build the query string using queryVal as the value,
and pass it to the geoprocessing tool (and apply the definitionQuery).
Doing it this way also gives the user a moment to inspect what she has typed,
before the (possibly nonsensical) value is applied as a query....
rereading your post, I see your concern is now with the query not working... oops.
Maybe breaking out the value setting and value applying, as I suggest, would help make the issue clearer.
JamesCrandall
Paste the result of the line:
print query
danielchaboya
print query
This is what is returned ...
JamesCrandall
Instead of:
Use:
danielchaboya
Instead of:
Use:
Thanks James, that did the trick. One thing, I had to change the name of the input dataset to this ...
arcpy.SelectLayerByAttribute_management(lyr, "NEW_SELECTION", query)
as the variable Lots is no longer being referenced.
Thanks again.
