Use txt file as Fields in attribute table
6259
12
02-05-2017 11:59 AM
AleahWorthem
I am attempting to write a script so that instead of hardcoding the name of the new field as "CONFIVALUE" for the confidence value, I want to use the name of the third column in the header of the input text file.
For example, let's say that the first line of the input text file looks like this:
Latitude,Longitude,Confidence
In this case the field name should be "Confidence".
If the first line looked like this:
Latitude,Longitude,ConfidValue
Then the field name should be "ConfidValue".
The error if i have conField indexed as conField[2]:
File "C:\Users\Aleah\Desktop\PythonScripts\Lab7_Q5.py", line 22, in <module>
IndexError: list index out of range
The error i am receiving if i remove the index is:
File "C:\Program Files (x86)\Wing IDE 101 4.1\src\debug\tserver\_sandbox.py", line 27, in <module>
File "C:\Program Files (x86)\ArcGIS\Desktop10.3\arcpy\arcpy\management.py", line 3246, in AddField
raise e
RuntimeError: Object: Error in executing tool
    import arcpy
    work = "C:\Scripts\Lab 7 Data\WildlandFires.mdb"
     arcpy.env.workspace = work # Set the workspace to the geodatabase
     iFile = "C:\Scripts\Lab 7 Data\NorthAmericaWildfires_2007275.txt"
     output = "NewFires.shp"
     threshold = 99
     f = open(iFile, 'r')# input text file C:\Scripts\Lab 7 Data\NorthAmericaWildfires_2007275.txt in "read" mode
     lstFires = f.readlines() # Read the lines of fire
     conField = []
     for line in f:
         comma = line.split(',')
         conField = comma
         print conField[2]
     field = ["SHAPE@", conField[2]] # represents the field names for each row in the feature class
     # Process: Create Feature Class
     arcpy.CreateFeatureclass_management(work, output, "POINT")
     arcpy.AddField_management(output, conField[2], "FLOAT")
     cursor_new = arcpy.da.InsertCursor(output, field)# add the new points that you will create to the "NewFires" feature class
     f.close() # close the file
     del cursor_new # release the cursor lock on the feature class
DarrenWiens2
So, now that you've got rid of the new line character using strip(), you can access it similar to how you were doing it before, using the [2] index:
lstFires[0].strip().split(',')[2]
RandyBurton
Your code:
arcpy.CreateFeatureclass_management(work, output, "POINT")‍‍‍‍‍‍‍‍‍‍‍
I get an error 000354 : The name contains invalid characters (a table in a file geodatabase cannot include a space or a period).
But, you are using an Access database?
AleahWorthem
Syntax
CreateFeatureclass_management (out_path, out_name, {geometry_type}, {template}, {has_m}, {has_z}, {spatial_reference}, {config_keyword}, {spatial_grid_1}, {spatial_grid_2}, {spatial_grid_3})
the MDB seems to be working
