Use list as input parameter to query FC
1560
05-05-2017 09:13 AM
jaykapalczynski
Honored Contributor
  1. I have a LIST containing SiteNames (this is a LIST i created named "mynewlist")
  2. I have a FC that has a SiteName field
I want to create a LIST / ARRAY of the data that is in the FC, where the List (mynewlist) and FC (Field "SiteName") are the same.
For instance...
I have 5 Sitenames in the LIST (# 1 above)
I have 200 Sitenames in the FC (#2 above)
I want a resulting LIST that is comprised of fields 1-9 from the FC where the LIST values are the same as the FC SiteName field.
Think I have everything in order just need help with the actual query???
 I don't even know if I can create a Query from a LIST and a FC....do I need to convert the list to something else first?
arcpy.env.workspace = "C:\\Users\\xxxx\\AppData\\Roaming\ESRI\\Desktop10.4\\ArcCatalog\\[email protected]"
myFCLayer = "BoatRampsWGS"
#Set variables for the FC above
var_SITENAME,var_WATERBODY,var_ACCESSAREA,var_BODYOFWATE = 'SITENAME' ,'WATERBODY','ACCESSAREA','BODYOFWATE'
var_TYPE,var_NO_OFRAMPS,var_COUNTY,var_REGION = 'TYPE','NO_OFRAMPS','COUNTY','REGION'
var_Lat,var_Long = 'Lat','Long'
QueryBoatRamps = [var_SITENAME,var_COUNTY,var_REGION,var_WATERBODY,var_BODYOFWATE,var_ACCESSAREA,var_TYPE,var_NO_OFRAMPS,var_Lat,var_Long]
# Build a query that will grab the records from the FC where the two SiteName fields are the same from the FC (BoatRampsWGS) and the LIST (myBoatRampList)
RampQry=  #Grab all the records from FC (BoatRampsWGS) where th4e Sitename is the same as the sitename in the LIST (myBoatRampList)
# write these records to a new list
BoatRampList=[]
with arcpy.da.SearchCursor(myFCLayer, QueryBoatRamps, RampQry) as cursor:
    for row in cursor:
        varBoatRampsList = str('{0},{1},{2},{3},{4},{5},{6},{7},{8},{9}'.format(row[0],row[1],row[2],row[3],row[4],row[5],row[6],row[7],row[8],row[9]))
        BoatRampList.append(varBoatRampsList)‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
jaykapalczynski
Honored Contributor
THINK I GOT IT....one minute for testing
I had to fix the apostrophe
if string.find(varQuery, "'") <> -1:
print 'fixing apostrophe in', varQuery, 'to be queryable.'
fn_name_qry = string.replace(varQuery, "'", "''")
print fn_name_qry
else:
fn_name_qry = varQuery
BoatRampList=[]
print ""
for i, val in enumerate(mynewMatchedlist):
    varQuery = val
    print varQuery
        print fn_name_qry
    else:
    #RampQry="""SITENAME = '{}'""".format(varQuery)
    RampQry="""SITENAME = '{}'""".format(fn_name_qry)
    #print RampQry
    with arcpy.da.SearchCursor(myLayer, QueryBoatRamps, RampQry) as cursor:
        for row in cursor:
    del cursor
print BoatRampList
jaykapalczynski
Honored Contributor
I can hard code a sitename and get a return...just don't know how to get it to read the LIST and give me a record for each value in the LIST.
How do I replace my LIST with the variable "varQuery"
varQuery = "Airfield Pond"
print RampQry
BoatRampList=[]
    for row in cursor:
del cursor
print BoatRampList‍‍‍‍‍‍‍‍‍‍‍‍
Result:
['Airfield Pond,Sussex,1,Airfield Pond,AIRFIELD POND,AIRFIELD POND,R,1.0,32.90782387,-80.02724715']
jaykapalczynski
Honored Contributor
I am trying this but getting an error...
ERROR:
File "E:\ArcGISProjects\BoatRampFacilities\PythonScripts\PythonSync\PythonScripts\~6_30days ago.py", line 170, in <module>
for row in cursor:
RuntimeError: Underlying DBMS error [[Microsoft][SQL Server Native Client 11.0][SQL Server]Incorrect syntax near 's'.] [DGIF_TEST.DBO.BoatRampsWGS]
LIST:  CALLED "matched"
['Airfield Pond', 'American Legion', 'Anthony Ford #4', 'Aylett', 'Blackwater', 'Blackwater Bridge', "Carey's", "Carter's Wharf", 'Coopers', 'Deep Bottom']
I think I am getting the error because the value has an apostrophe????
Carey's
BoatRampList=[]
for i, val in enumerate(matched):
    varQuery = val
    print varQuery
    #print RampQry
        for row in cursor:
    del cursor
print BoatRampList‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson_Retired
side tangent...
A tip
row = [1, 'a', 3, 'b', 5, 6, 7, 'c', 'd']
frmt = ("{}, "*len(row)).format(*row)  # to account for unknown
print(frmt[:-2])  # snip off the extra comma and space
1, a, 3, b, 5, 6, 7, c, d
# alternative 2
", ".join(["{}".format(i) for i in row])  # just saves the snip
'1, a, 3, b, 5, 6, 7, c, d'
jaykapalczynski
Honored Contributor
print fn_name_qry
else:
BoatRampList=[]
print ""
    varQuery = val
    print varQuery
        print fn_name_qry
    else:
    #print RampQry
        for row in cursor:
    del cursor
print BoatRampList
