Updating 2 tables related by 3 ID fields
11065
14
02-26-2015 12:57 AM
DavinShokes1
I'm having a little trouble setting up this script. Here are the bullet points.
  • 2 Tables have the same three fields. [SiteID], [EasyID], [FeatureID]. For simplicity, lets pretend these are the only fields (besides OID).
  • [FeatureID] is a unique integer for each feature created in Table 1.
  • [SiteID] is a non-unique integer and groups features by location.
  • [EasyID] is a string (typically a number) unique within the same [SiteID], but not unique in the field.
  • Table 1 - The master table. New features have all three ID fields populated.
  • Table 2 - New features always have [SiteID], sometimes [EasyID], and never a [FeatureID].
  • Table 2 - Features with [SiteID] and [EasyID], and no [FeatureID] may have a matching [SiteID] and [EasyID] in Table 1. If so, update [FeatureID] in Table 2.
  • Table 2 - Features missing [EasyID] need to be assigned the next number for that [SiteID] in either Table 1 or 2. If current EasyID's for a site are '1', '3', '4A', '6-7','S', and '55', new features would be '2', '4', '5', '6', '7', '8'....etc.
  • Table 2 - New features given a [FeatureID] when inserted into Table 1. The features are then updated in Table 2.
  • Table 1 - Finally, any features with a [SiteID] in Table 2, but the [FeatureID] and [EasyID] are not in Table 2, are inserted into Table 2
  • At the end of the script both tables should match.
I've looked through using model builder with no luck. With python dictionaries and search cursors i'm getting stuck trying to join against [SiteID] and [EasyID] at the same time. I am also don't know how to return the dictionaries with just integer EasyID's and loop through updating the next smallest integer.
Here is what I've got so far. Much of it stems from what I read from Richard Fairhurst's post Turbo Charging Data Manipulation with Python Cursors and Dictionaries
import arcpy
#Tables
T1 = r"C:\Python\Scratch.gdb\Table1"
T2 = r"C:\Python\Scratch.gdb\Table2"
fields = ["FeatureID", "SiteID", "EasyID"]
# Get FeatureID dictionaries for each Table
T1Dict = {r[0]:(r[0:]) for r in arcpy.da.SearchCursor(T1, fields)}
T2Dict = {r[0]:(r[0:]) for r in arcpy.da.SearchCursor(T2, fields)}
# Get SiteID+EasyID dictionaries for each Table
T1ConcatDict = {str(r[1]) + "," + str(r[2]):(r[0]) for r in arcpy.da.SearchCursor(T1, fields)}
T2ConcatDict = {str(r[1]) + "," + str(r[2]):(r[0]) for r in arcpy.da.SearchCursor(T2, fields)}
#First, If T2.FeatureID is Null but T2.EasyID and T2.SiteID are in T1, Update T2.FeatureID
with arcpy.da.UpdateCursor(T2, fields) as updateRows:
    for updateRow in updateRows:
        # store the Join value by combining 3 field values of the row being updated in a keyValue variable
        keyValue = str(updateRow[1]) + "," + str(updateRow[2])
        # verify that the keyValue is in the Dictionary
        if keyValue in T1ConcatDict & updateRow[0] is None & updateRow[1] is not None:
            # transfer the value stored under the keyValue from the dictionary to the updated field: FeatureID.
            updateRow[0] = T1ConcatDict[keyValue][0]
            updateRows.updateRow(updateRow)
#Rebuild Dictionary if it is needed again
#Get Max(EasyID) within SiteID
NumberList = []
for value in T1Dict[2]:
    try:
        NumberList.append(int(value))
    except ValueError:
        continue
T1EasyNumberDict = [s[2] for s in T1Dict[2] if s.isdigit()]
T1MaxEasyDict = max(T1EasyNumberDict)
#Second, If T2.FeatureID and T2.EasyID are Null, Update T2.EasyID with next smallest number (as string) in either T1 or T2 for the specific SiteID
        if keyValue in T1Dict & updateRow[0] is None & updateRow[1] is None:
            # transfer the value stored under the keyValue from the dictionary to the updated field.
            # Perhaps retrieve max int occurs here?
  updateRow[2] = max(T1Dict[keyValue][2], T2Dict[keyValue[2])
#Third, Insert into T1 if T2.SiteID is not null and T2.EasyID is not null
#Forth, Update T2.FeatureID with T1.FeatureID from previous insert where T2.SiteID=T1.SiteID and T2.EasyID=T1.EasyID
#Lastly, Insert any T1 features into T2 where T1.EasyID not in (Select EasyID from T2 where T2.SiteID = T1.SiteID) and T1.FeatureID  not in (Select FeatureID from T2)
Thank you for any advise.
Edit: Here is a sample of sites with 2 explanatory columns
T1.FeatureIDT2.FeatureIDT1.SiteIDT2.SiteIDT1.EasyIDT2.EasyIDStatusResult
35858935858913623813623811Existing T1 and T2 FeatureNo Change
35859035859013623813623822Existing T1 and T2 FeatureNo Change
35859435859413623813623844Existing T1 and T2 FeatureNo Change
65253865253813623813623855Existing T1 and T2 FeatureNo Change
48602848602813623813623888Existing T1 and T2 FeatureNo Change
48602948602913623813623899Existing T1 and T2 FeatureNo Change
5253005253001362381362383434Existing T1 and T2 FeatureNo Change
574802574802136238136238998998Existing T1 and T2 FeatureNo Change
670911136238300New T1 Feature(Step 6) Inserted Into T2
4938401362389996New T1 Feature(Step 6) Inserted Into T2
4938391362389997New T1 Feature(Step 6) Inserted Into T2
4938311362389999New T1 Feature(Step 6) Inserted Into T2
696019136238105-106New T1 Feature(Step 6) Inserted Into T2
6960371362389999NNew T1 Feature(Step 6) Inserted Into T2
696014136238Area1New T1 Feature(Step 6) Inserted Into T2
670910136238NNew T1 Feature(Step 6) Inserted Into T2
580636136238N30cNew T1 Feature(Step 6) Inserted Into T2
360401136401ACExiting T1 Feature(Skip) Not Inserted since no T2.SiteID match
360402136401SPExiting T1 Feature(Skip) Not Inserted since no T2.SiteID match
360510136427Area 1Exiting T1 Feature(Skip) Not Inserted since no T2.SiteID match
36265313663515Exiting T1 Feature(Skip) Not Inserted since no T2.SiteID match
36294336294313669813669811Existing T1 and T2 FeatureNo Change
36294436294413669813669822Existing T1 and T2 FeatureNo Change
36294536294513669813669833Existing T1 and T2 FeatureNo Change
36294636294613669813669844Existing T1 and T2 FeatureNo Change
36294736294713669813669855Existing T1 and T2 FeatureNo Change
36295036295013669813669811C11CExisting T1 and T2 FeatureNo Change
3629483629481366981366988New T2 Feature, Exists in T1(Step 5) Update T2.EasyID
3629493629491366981366989New T2 Feature, Exists in T1(Step 5) Update T2.EasyID
3629511366981366981515New T2 Feature, Exists in T1(Step 1) Update T2.FeatureID
3629541366981366981616New T2 Feature, Exists in T1(Step 1) Update T2.FeatureID
3629551366981366981717New T2 Feature, Exists in T1(Step 1) Update T2.FeatureID
3629561366981366981818New T2 Feature, Exists in T1(Step 1) Update T2.FeatureID
3629571366981366981919New T2 Feature, Exists in T1(Step 1) Update T2.FeatureID
13669820New T2 Feature(Step 3,4) Insterted into T1, Update T2.FeatureID
13669821New T2 Feature(Step 3,4) Insterted into T1, Update T2.FeatureID
13669822New T2 Feature(Step 3,4) Insterted into T1, Update T2.FeatureID
13669825New T2 Feature(Step 3,4) Insterted into T1, Update T2.FeatureID
136698New T2 Feature(Step 2,3,4) Get next lowest integer for T2.EasyID -> 6
136698New T2 Feature(Step 2,3,4) Get next lowest integer for T2.EasyID -> 7
136698New T2 Feature(Step 2,3,4) Get next lowest integer for T2.EasyID -> 10
136698New T2 Feature(Step 2,3,4) Get next lowest integer for T2.EasyID -> 11
DavinShokes1
I've made some headway. My script is successfully insertings new rows into sql server with pyodbc. However, I've got an encoding issue when updating the hosted layer. The sql table varchar columns and I assume that hosted layers are nvarchar. The call to update the hosted layer succeeds but the text column doesn't actually update. Integer fields do.
Here is my code I've kept the actual column names so the SQL Server table fields are:
SiteID-->CustomerID, FeatureID-->PropertyID, and EasyID--> Location
The hosted layer fields are:
SiteID-->CustomerID, FeatureID-->PropertyID_WO, and EasyID--> TAG
I've match the sequence to prevent name issues. I'm don't know how to go further without figuring out how to update TAG with Location.
# -*- coding: utf-8 -*-
import sys, os, datetime, arcpy, pyodbc, time, uuid
def hms_string(sec_elapsed):
    h = int(sec_elapsed / (60 * 60))
    m = int((sec_elapsed % (60 * 60)) / 60)
    s = sec_elapsed % 60.
    return "{}:{:>02}:{:>05.2f}".format(h, m, s)
# End hms_string
def timedif(end_datetime, start_datetime):
    seconds_elapsed = (end_datetime - start_datetime).total_seconds()
    return hms_string(seconds_elapsed)
# End timedif
start_time = datetime.datetime.now()
print "# Script start: {}".format(start_time)
from arcpy import env, da
from arcrest.security import AGOLTokenSecurityHandler
from arcrest.agol import FeatureService
from arcrest.agol import FeatureLayer
from arcrest.common.filters import LayerDefinitionFilter
from datetime import timedelta
print "# Imports loaded."
# Set Geoprocessing environments
Scratch_gdb = r'C:\Python\scratch.gdb'
arcpy.env.scratchWorkspace = Scratch_gdb
arcpy.env.workspace = Scratch_gdb
Local_Table = r'C:\Users\dkshokes\AppData\Roaming\ESRI\Desktop10.3\ArcCatalog\RTC03.sde\Rainbow.dbo.Property'
Output_Table_1 = "T1"
Expression_1 = r'"CustomerID" = 166602 AND "Location" is not Null'
Online_Trees = r'http://services.arcgis.com/###/arcgis/rest/services/###/FeatureServer/0'
username = "####"
password = "####"
proxy_port = None
proxy_url = None
agolSH = AGOLTokenSecurityHandler(username=username, password=password)
Output_Table_2 = "T2"
Expression_2 = '"CustomerID" = 166602'
fields_1 = ['CustomerID', 'Location', 'PropertyID', 'OID@', 'Description', 'CBH', 'PropertyQuantity', 'PropertyItemID', 'DateEntered', 'LastChangeDate', 'Special_Note']
fields_2 = ['CustomerID', 'TAG', 'PropertyID_WO', 'OID@', 'COMMON', 'DBH', 'QTY', 'PropertyItemID', 'CreationDate', 'EditDate', 'Notes', 'Creator', 'Editor', 'PruneYear', 'ProposalStatus', 'SoilYear']
print "\n# Online variables loaded.  "
# Local variables:
T1 = Scratch_gdb + "\\" + Output_Table_1
print "# T1 Table: {}".format(T1)
print "# T1 Fields: {}".format(fields_1)
T2 = Scratch_gdb + "\\" + Output_Table_2
print "# T2 Table: {}".format(T2)
print "# T2 Fields: {}".format(fields_2)
FieldMap_1 = r"PropertyID \"PropertyID\" true true false 50 Long 0 10 ,First,#," + Local_Table + ",PropertyID,-1,-1;CustomerID \"CustomerID\" true true false 4 Long 0 10 ,First,#," + Local_Table + ",CustomerID,-1,-1;Location \"Location\" true true false 7 Text 0 0 ,First,#," + Local_Table + ",Location,-1,-1;PropertyItemID \"PropertyItemID\" true true false 4 Long 0 10 ,First,#," + Local_Table + ",PropertyItemID,-1,-1;Description \"Description\" true true false 255 Text 0 0 ,First,#," + Local_Table + ",Description,-1,-1;PropertyQuantity \"PropertyQuantity\" true true false 4 Long 0 10 ,First,#," + Local_Table + ",PropertyQuantity,-1,-1;CBH \"CBH\" true true false 8 Double 1 18 ,First,#," + Local_Table + ",CBH,-1,-1;Special_Note \"Special_Note\" true true false 255 Text 0 0 ,First,#," + Local_Table + ",Special_Note,-1,-1;Status \"Status\" true true false 10 Text 0 0 ,First,#," + Local_Table + ",Status,-1,-1;DateEntered \"DateEntered\" true true false 36 Date 0 0 ,First,#," + Local_Table + ",DateEntered,-1,-1;PropertyGroup \"PropertyGroup\" true true false 2 Short 0 1 ,First,#," + Local_Table + ",PropertyGroup,-1,-1;Removed \"Removed\" true true false 2 Short 0 1 ,First,#," + Local_Table + ",Removed,-1,-1;LastChangeDate \"LastChangeDate\" true true false 36 Date 0 0 ,First,#," + Local_Table + ",LastChangeDate,-1,-1"
if arcpy.Exists(T1):
    arcpy.Delete_management(T1)
    print "Previous T1 Found so it was deleted."
if arcpy.Exists(T2):
    arcpy.Delete_management(T2)
    print "Previous T2 Found so it was deleted."
#print "\n# Local variables loaded...Making temporary business table."
arcpy.TableToTable_conversion(Local_Table, Scratch_gdb, Output_Table_1, Expression_1, FieldMap_1, "")
#print "# Successfully made temporary business table."
#print "\n# Querying Feature Layer and Making Temporary Feature Class."
fl = FeatureLayer(Online_Trees, securityHandler=agolSH, initialize=False,proxy_url=proxy_url, proxy_port=proxy_port)
print fl.query(where=Expression_2, out_fields='*', returnGeometry=True, returnIDsOnly=False, returnCountOnly=False, returnFeatureClass=True, out_fc=Output_Table_2)
print "\n# Ready to compare." + "  Time elapsed: {}".format(timedif(datetime.datetime.now(), start_time))
print "\n# Intialize T1 as a concatenated dictionary"
T1Dict = {}
# Initialize a list to hold any concatenated key duplicates found
T1KeyDups = []
# Open a search cursor and iterate rows
with arcpy.da.SearchCursor(T1, fields_1) as searchRows:
    for searchRow in searchRows:
        # Build a composite key value from 2 fields: CustomerID;TAG
        keyValue = '{};{}'.format(searchRow[0], searchRow[1]).decode('utf-8')
        if not keyValue in T1Dict and searchRow[1] is not None:
            # Key not in dictionary.  Add Key pointing to a list of a list of field values
            T1Dict[keyValue] = [list(searchRow[0:])]
            #print "T1Dict keyValue: {}".format(keyValue)
        elif searchRow[1] is not None:
            # Key in dictionary.  Append a list of field values to the list the Key points to
            T1KeyDups.append(keyValue)
            T1Dict[keyValue].append(list(searchRow[0:]))
        #print T1Dict[keyValue][0:]
del searchRows, searchRow
##print "\n# Sample of how to access the keys, record count, and record values of the dictionary"
##for keyValue in T1Dict.keys():
##    for i in range(0, len(T1Dict[keyValue])):
##        print "T1Dict Key CustomerID;TAG is {} Record:{} of {} PropertyID_WO:{} ObjectID:{}.".format(keyValue, i+1, len(T1Dict[keyValue]), T1Dict[keyValue][0], T1Dict[keyValue][1])
if len(T1KeyDups) > 0:
    print "T1KeyDups keys found! {}".format(T1KeyDups)
    # fix T1 here
else:
    print ("No Duplicates!")
print "\n# T1Dict Complete:" + "  Time elapsed: {}".format(timedif(datetime.datetime.now(), start_time))
print "\n# Get the list of TAGs associated with each CustomerID in a dictionary for T1"
T1CustomerIDDict = {}
        keyValue = searchRow[0]
        if not keyValue in T1CustomerIDDict:
            T1CustomerIDDict[keyValue] = [searchRow[0:]]
        else:
            # Append a list of field values to the list the Key points to
            T1CustomerIDDict[keyValue].append(searchRow[0:])
        #print T1CustomerIDDict[keyValue]
print "\n# T1CustomerIDDict Complete"
print "\n# Get the list of TAGs associated with each CustomerID in a dictionary for T2"
T2CustomerIDDict = {}
with arcpy.da.SearchCursor(T2, fields_2) as searchRows:
        if not keyValue in T2CustomerIDDict:
            T2CustomerIDDict[keyValue] = [searchRow[0:]]
        else:
            T2CustomerIDDict[keyValue].append(searchRow[0:])
print "\n# T2CustomerIDDict Complete"
print "\n# Creating CustomerIDDict"
CustomerIDDict = {}
for keyValue in T2CustomerIDDict.keys():
    intList = []
    for TAG in T2CustomerIDDict[keyValue]:
        try:
            if TAG[1]:
                TAG = int(TAG[1])
                intList.append(TAG)
        except:
            print "Error with T2.TAG"
    if keyValue in T1CustomerIDDict:
        for TAG in T1CustomerIDDict[keyValue]:
            try:
                if TAG[1]:
                    TAG = int(TAG[1])
                    intList.append(TAG)
            except:
                print "Error with T1.TAG"
    #print "\nnumeric T2.TAGs: {}".format(set(intList))
    #print "\nnumeric T1.TAGs: {}".format(set(intList))
    # remove already used numbers out of the numbers from 1 to 9999
    # and get a sorted list for use with an update cursor.
    CustomerIDDict[keyValue] = sorted(set(range(1, 200)) - set(intList))
print "\n# CustomerIDDict Complete"
print "\n# Inserting and Updating" + "  Time elapsed: {}".format(timedif(datetime.datetime.now(), start_time))
### This cursor sucessfully inserts into sql server a new row with an unused TAG and attributes from the hosted feature.
### It then updates the hosted layer fields propertyID_WO and TAG.
##  propertyID_WO succeeds but TAG is blank
print "#  Working with pyodbc sql stuff"
cnxn_SQL = pyodbc.connect(Trusted_Connection='yes', Driver = '{SQL Server Native Client 10.0}', Server = '###', database = '###')
cursor_SQL = cnxn_SQL.cursor()
with arcpy.da.UpdateCursor(T2, fields_2) as updateRows:
        # if T2.Row has TAG and CustomerID but no PropertyID compare and look for match in T1
        if (updateRow[2] == None) and not (updateRow[1] == None):
            print "1st if TAG {} PropertID {}".format(updateRow[1],updateRow[2])
            for valu in T1CustomerIDDict[updateRow[0]]:
                if valu[1] == updateRow[1]:
                    try:
                        updateRow[2] = valu[2]
                        print "# Updating PropertyID_WO for TAG:{} hosted layer with {}".format(updateRow[1],updateRow[2])
                        fl.calculate(where="OBJECTID={} AND CustomerID={} AND TAG={}".format(updateRow[3], updateRow[0], updateRow[1]), calcExpression={"field" : "PropertyID_WO", "value" : "{}".format(updateRow[2])})
                        print "# Success"
                    except:
                        print "# Failed Hosted Update of PropertyID"
        if (updateRow[1] == None) and (updateRow[2] == None):
            print "3rd if TAG {} PropertID {}".format(updateRow[1],updateRow[2])
            newPropID = None
            print CustomerIDDict[updateRow[0]][0]
            # Set templist to show available integer TAGs for 1 CustomerID at a time.
            templist = CustomerIDDict[updateRow[0]]
            # Set Null tag to first available integer
            print updateRow[1:3]
            updateRow[1] = templist[0]
            # Insert to local sql server table, update online from sql results, then Remove used tag.
            try:
                # Get ItemID required by insert trigger
                propitemid = cursor_SQL.execute("SELECT [PropertyItemID] from [TREESPECIESRELATIONSHIPTABLE] Where [COMMON__GIS_name_] = ?",updateRow[4]).fetchone()[0]
                # Insert New trees into T1
                cursor_SQL.execute("IF NOT EXISTS (SELECT 1 FROM Property WHERE CustomerID = ? and Location = ?) INSERT INTO Property(CustomerID, Location, Description, CBH, PropertyQuantity, PropertyItemID, DateEntered, LastChangeDate, Special_Note) values (?,?,?,?,?,?,?,?,?)", updateRow[0], updateRow[0], updateRow[0],updateRow[1],updateRow[4],updateRow[5],updateRow[6],propitemid,updateRow[8],updateRow[9],updateRow[10])
                cnxn_SQL.commit()
                # Grab to primary key for updating hosted layer
                newPropID = cursor_SQL.execute("Select PropertyID From Property where CustomerID=? AND Location=?", updateRow[0], updateRow[1]).fetchone()[0]
                print "Finished Insert for New PropertyID {}".format(newPropID)
                cnxn_SQL.commit()
                updateRow[2] = newPropID
                templist.remove(updateRow[1])
            except:
                print "# Failed SQL Server Insert"
            try:
                print "# Updating TAG and PropertyID_WO for hosted layer"
                print fl.calculate(where="OBJECTID={} AND CustomerID={}".format(updateRow[3], updateRow[0]), calcExpression={"field" : "TAG", "value" : "{}".format(updateRow[1]),"field" : "PropertyID_WO", "value" : "{}".format(updateRow[2])})
            except:
                print "# Failed Hosted Update of TAG and PropertyID"
del updateRows, updateRow
cnxn_SQL.close()
print "Finished!" + "  Time elapsed: {}".format(timedif(datetime.datetime.now(), start_time))
RichardFairhurst
I am not clear which part of the code is causing the problem and which field name is for an integer and which is for a string.  Generally to use Python to write to a string field you have to enclose non-strings in the str() method.  For converting strings to integers you must always test that the string is actually an integer and use Null (or some other default value for blank numbers) when the strings is not numeric.  For example, " " is not an integer and will fail if you try to convert it to an integer.  Potentially Null will also cause a problem.
Anyway, any time type conversion is involved in a script it is easy to produce errors and unexpected results until you include enough logic to handle both the values that can convert and the values that can't convert at each conversion step.  To confirm for yourself what is failing you should include a print statement in your try except block to show you the actual value read from the source field that you are trying to write to the field that is rejecting the value or producing bad results.
DavinShokes1
The last try at line 230 is where it is succeeding the REST call, but the layer's field values stay null. A few lines prior, updateRow[1] gets an integer from the dictionary CustomerIDDict.
Then updateRow[1] gets put into...
I'm guessing it turns into: calcExpression={"field" : "TAG", "value" : "4",....},but I'm not certain.
Also, at line  97 added a decode and a typeerror went away. I can't tell if this decode causes issues in the dictionary later on though.
RichardFairhurst
Actually, line 230 is a print statement.  Are you sure it is executing?  You should break that whole expression down to multiple prints statements so you are certain exactly what arguments are being passed to the query and calculation.  For example, you could try:
print "OBJECTID={} AND CustomerID={}".format(updateRow[3], updateRow[0])
print "{}".format(updateRow[1])
print "{}".format(updateRow[2])
Then, if all of those inputs makes sense, execute the fl.calculate outside of a print operation.
There are some details to pay attention to.  If CustomerID is numeric and the value makes sense, then the SQL should be fine.  But if CustomerID is a string value then the SQL should fail, since the value is not within quotes.  For a string CustomerID you would need:  "OBJECTID={} AND CustomerID='{}'".format(updateRow[3], updateRow[0])
DavinShokes1
I figured it out. I was trying to update 2 different fields at once and field calculator understandably only takes one. Its crazy how much time I looked up information on unicode stuff only to find it was a misuse of the parameter.
Can't thank you enough Richard. I should be able to fumble through the rest of the conditionals.
