updateConnectionProperties() is not working
6662
12
09-28-2023 09:40 AM
NSamu
I am trying to update connection properties for all layers in a Pro project map that are connected to our admin database to a read-only version of that database. When I run the following script, it runs but the database connections do not get updated.
import arcpy
aprx = arcpy.mp.ArcGISProject("CURRENT")
for m in aprx.listMaps("Mobile_Map"):
for lyr in m.listLayers():
if not(lyr.isGroupLayer or lyr.isBasemapLayer):
try:
lyr.updateConnectionProperties(current_connection_info="A:\DBConnection\admin.sde", new_connection_info="A:\DBConnection\dr.sde")
except:
print("Not an sde database or the database connection does not need to be updated.")
Tags (3)
BlakeTerhune
Oh, glad you got it working!
As another suggestion, consider handling your exceptions a more specific, targeted manner. With your snippet, you will never know if there was some other problem with updateConnectionProperties() because you're printing a generic message for all exceptions. You need to know if something unexpected is happening, which your error handling will not show. I've started doing this as a pattern to add more information/context to errors.
import arcpy
        if lyr.supports("connectionProperties"):
            try:
                print(lyr.connectionProperties["connection_info"])
                lyr_update = lyr.connectionProperties
                lyr_update['connection_info']['password']='<password>'
                lyr_update['connection_info']['user']='dr'
                lyr.updateConnectionProperties(lyr.connectionProperties, lyr_update)
            except Exception as e:
                raise Exception("Not an sde database or the database connection does not need to be updated.") from e
aprx.save()
del aprx
If you really want to pass on some specific error, you can handle that specifically. In this example, all arcpy errors will get passed and the code will continue running, but it will stop if the exception is not from arcpy (unhandled).
except arcpy.ExecuteError as arcpy_e:
    print(arcpy_e)
    pass
NSamu
Thank you for this advice. Very helpful and much appreciated.
RogerDunnGIS
I have to write two Python scripts, one for ArcMap and one for ArcGIS Pro, in order to fix all the geodatabase connections in map documents and Pro projects after we change 30+ passwords at a future date.  It's unfortunate that the Pro script will have to access a file (or have hard-coded) all the new passwords in order for this to work!  The ArcMap script will have no such problems, with all the testing I've done (the biggest hang-up there is that the "Database" key does not appear in the serviceProperties dictionary when the connection can't be established).  No combination of arguments for the updateConnectionProperties method seems to work other than the one marked in this thread as the solution.  I would have preferred to just reference a new .sde file, but that just doesn't work.
