Update attributes of selected
5715
20
09-10-2020 11:06 AM
2Quiker
Trying to update some well data from another layer. I am trying to do this in Arcmap (10.6) with a tool/script (3.6.10 Python).
I need to transfer attributes from WellParcels to WellsPoints. I would like to do this with out starting a Edit session in python if possible as this tends to slow down the process...? I would manual start an edit session in ArcMap then run the tool/script when I have points selected, I currently have the following but error out on line 44. I am not sure this is the best/fastest way of doing it, so if someone has a different idea please share how I would do this with my data.
import arcpy,os
arcpy.env.overwriteOutput = True
arcpy.env.workspace = r'Database Connections\Connection to blah.sde'
ptSelection = "WellPoints"
pointLayer = arcpy.env.workspace + os.sep + "WellPoints"
parcel = 'WellParcels'
sjpoints = "In_memory\sjpoints"
try:
    ptCount = int(arcpy.GetCount_management(ptSelection).getOutput(0))
    dsc = arcpy.Describe(ptSelection)
    selection_set = dsc.FIDSet
    if len(selection_set) == 0:
        print "There are no features selected"
    elif ptCount >= 1:
        arcpy.SelectLayerByLocation_management(parcel,"INTERSECT",ptSelection)
        arcpy.MakeFeatureLayer_management(parcel,"parcel_lyr")
        arcpy.SpatialJoin_analysis(ptSelection, "parcel_lyr" , sjpoints)
        #sourceFieldsList = 'WellID', 'dept', 'type', ' Geothermal' 'GeoWaterUs', 'Temp', 'TempDate'
        #valueDict = {r[0]:(r[1:]) for r in arcpy.da.SearchCursor(sjpoints, sourceFieldsList)}
        fldList = ['WellID', 'dept', 'type', ' Geothermal' 'GeoWaterUs', 'Temp', 'TempDate']
        fldDict ={}
        print (fldDict)
        targetFields = ['W_ID', 'dept', 'type', ' Geothermal' 'GeoWaterUs', 'Temp', 'TempDate']
        with arcpy.da.UpdateCursor(ptSelection, targetFields) as cursor:
            for row in cursor
            row[0] = ['W_ID']
            row[1] = ['dep']
            row[2] = ['type']
            row[3] = ['Geothermal']
            row[4] = ['GeoWaterUs']
            row[5] = ['Temp']
            row[6] = ['TempDate']
            #Attributes from Wellparcels
            curosr.append(fldDict['Account', 'dept', 'type', ' Geothermal' 'GeoWaterUs', 'Temp', 'TempDate'])
except Exception, e:
    # If an error occurred, print line number and error message
    import traceback, sys
    tb = sys.exc_info()[2]
    print("Line %i" % tb.tb_lineno)
    arcpy.AddMessage("Line %i" % tb.tb_lineno)
    print(e.message)
    arcpy.AddMessage(e.message)  ‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
JoshuaBixby
MVP Esteemed Contributor
On line #44, cursor is spelled wrong.  Also, the ArcPy DA update cursor doesn't have an append method.
2Quiker
Got it, thanks. So with arcpy.da.UpdateCursor can on be updated with arcpy.da.Editor. I am trying to do this inside Arcmap with an editor session started but it seems as if i use arcpy.da.UpdateCurosr it won't let me.
JoshuaBixby
Yes, update cursors can be used within edit sessions.  What is the code you are running, and what exactly is the error and traceback?
DanPatterson
You can't be using python 3.6.10 because
would have errored out.
Also, line 35 needs a colon
for row in cursor
and 36-43 need to be indented.
And, why not remove the try- except stuff, dedent your code accordingly so you get unaltered error messages.
You get trackback error lines numbers and error messages without them AND no errors get hidden or obfuscated.
... sort of retired...
2Quiker
Your right I am on 2.7.14.
I figured that I was on 3.6.10 because that the version of the shell I am using.
2.7.14 (v2.7.14:84471935ed, Sep 16 2017, 20:19:30) [MSC v.1500 32 bit (Intel)]
1.5.2
1.9.3
0.17.0
2Quiker
I was able to find something that works but it currently only works for one feature at a time, I need it to work with one or 10,20,50. How can I get this to work with with multiple selected features?
import arcpy,os
elif ptCount >= 1:
    fldDict ={}
    if int(arcpy.GetCount_management("parcel_lyr").getOutput(0))==1:
        for parrow in arcpy.da.SearchCursor("parcel_lyr",fldList):
            for w in range(len(fldList)):
                fldDict[fldList]=parrow
    del parrow
        for row in cursor
        row = []
        row.append(fldDict['WellID']
        row.append(fldDict['dep']
        row.append(fldDict['type']
        row.append(fldDict['Geothermal']
        row.append(fldDict['GeoWaterUs']
        row.append(fldDict['Temp']
        row.append(fldDict['TempDate']
        rows.updateRow(row)
    del row
DanPatterson
You still didn't fix the rest like I suggested.  Lines 34 onward
you need a colon after cursor
The remaining lines need to be indented
you redefine row as an empty list
Did you not get any error messages?
        for row in cursor
        row = []
        rows.updateRow(row)
2Quiker
I thought I had pasted the code with the indent and when I pasted the code and without the empty list but I didn't, sorry about that.
The code does have the the indent and empty list removed.
import arcpy,os
elif ptCount >= 1:
    fldDict ={}
    del parrow
        for row in cursor:
            rows.updateRow(row)
    del row‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍‍
DanPatterson
tiny steps... tiny steps...
you still didn't get the crucial line correct
for row in cursor
should be
for row in cursor:
