update attribute table from another table based on a query
14178
27
11-16-2017 12:55 AM
Henryobaseki
Here is my script
import arcpy
... from arcpy import env
... env.workspace = "C:\\Data"
... print 'Processing...'
... fc = "Updated_subset.dbf"
... cursor = arcpy.da.SearchCursor(fc, ["OID"])
... for row in cursor:
...     SQL_stat= "OID = "+ str(row[0])
...     fc2 = "airports_old.dbf"
...     cursor2 = arcpy.da.SearchCursor(fc, ["STATE"], SQL_stat)
...     for row2 in cursor2:
...         UpdatedValue = row2[0]
...         cursor3 = arcpy.da.UpdateCursor(fc2, ["STATE"],SQL_stat)
...         for row3 in cursor3:
...             row3[0] = UpdatedValue
...             cursor3.updateRow(row3)
... del row
... del cursor
... del row2
... del cursor2
... del row3
... del cursor3
... print "Done"
At the moment the script below  the OID is coneverted to string
How do I rewrite the SQL stat if the OID Field is already a string, hence, don't need to convert to string
Thanks for your help!
XanderBakker
Esri Esteemed Contributor
From the code you posted it looks like you are trying to do something like this:
import arcpy
env.workspace = r"C:\Data"
tbl1 = "Updated_subset.dbf"
tbl2 = "airports_old.dbf"
fld_oid = "OID"
fld_state = "STATE"
dct = {r[0]: r[1] for r in arcpy.da.SearchCursor(tbl1, (fld_oid, fld_state))}
with arcpy.da.UpdateCursor(tbl2, (fld_oid, fld_state)) as curs:
    for row in curs:
        oid = row[0]
        state = row[1]
        if oid in dct:
            row[1] = dct[oid]
            curs.updateRow(row)
However, it doesn't make much sense to me. The OID in both tables correspond and using the OID you want to update the State in tbl2 with the one in tbl1?
Henryobaseki
Hi  Xander,
I keep getting  runtime errors
>>> import arcpy
... env.workspace = r"C:\Users\L0505857\Data"
... tbl1 = "Updated_subset.dbf"
... tbl2 = "airports_old.dbf"
... fld_oid = "OID"
... fld_state = "state"
... dct = {r[0]: r[1] for r in arcpy.da.SearchCursor(tbl1, (fld_oid, fld_state))}
... with arcpy.da.UpdateCursor(tbl2, (fld_oid, fld_state)) as curs:
... for row in curs:
... oid = row[0]
... state = row[1]
... if oid in dct:
... row[1] = dct[oid]
... curs.updateRow(row)
Runtime error
File "<string>", line 11, in <module>
File "<string>", line 11, in <dictcomp>
RuntimeError: A column was specified that does not exist.
XanderBakker
This error indicates that either "OID" or "state" is not a field that you have in your table "Updated_subset.dbf". Can you check?
Henryobaseki
The two tables have  state and OID RESID attributes
I want to use the state field  attributes in Updated-subset.dbf to update the state field  attribute in airport.dbf which is currently empty
I  want the update to occur if the OID  and the RESID in both tables match.
I m still getting the same runtime error
XanderBakker
Strange. Can you run the snippet below and post back what it prints?
import arcpy
tbl1 = r"C:\Users\L0505857\Data\Updated_subset.dbf"
for fld in arcpy.ListFields(tbl1):
    print(fld.name)
Henryobaseki
OID
OBJECTID
ID
FIELD_NAME
KEY_WELL
WATER_DEPT
BASIN_NAME
TOT_RECOVE
HC_TYPE
OVP_bar
Res_Age
Formation
Lithology
RESID
Regional_s
XanderBakker
There you go, there is no "state" field in the table. This is what causes the error on line 11:
On this line, a dictionary is used reading the state field, but if it doesn't exist, it will return an error.
You also mention a field called "RESID" that should be used in the code, but it is not referenced anywhere in the code. Do I understand it correctly that the field "RESID" from  Updated_subset.dbf should match the field "OID" from airports_old.dbf?
Can you also list the field from table airports_old.dbf with this snippet and post these:
import arcpy
tbl2 = r"C:\Users\L0505857\Data\airports_old.dbf"
for fld in arcpy.ListFields(tbl2):
    print fld.name
And please explain what field in which table needs to be updated by what information when which condition is met. In case a field should be added before the update, please indicate that too.
Henryobaseki
Thanks Xander, I was looking at the wrong table.
Code works!
XanderBakker
OK, great, then ignore the additional questions I just posted.
Henryobaseki
If I want to add another field RESID to the search cursor
I ' m stuck at dct
see below ......
import arcpy
fld_oid = "OID"
fld_FIELD_NAME = "FIELD_NAME"
fld_RESID = "RESID"
dct = {r[0]: r[1] for r in arcpy.da.SearchCursor(tbl1, (fld_oid, fld_FIELD_NAME,fld_RESID))}
with arcpy.da.UpdateCursor(tbl2, (fld_oid, fld_FIELD_NAME,fld_RESID)) as curs:
    for row in curs:
        oid = row[0]
        FIELD_NAME = row[1]
        if oid in dct:
            row[1] = dct[oid]
            curs.updateRow(row)
