Trying to run a model / script as a scheduled task
6010
12
06-12-2012 08:34 AM
SharonZastre
I have created a model that will Analyze, Sync, and Compress data within a SQL Enterprise geodatabase (ArcGIS 10 SP4). The model runs fine in ArcCatalog. I exported the model to a python script and it runs fine in ArcCatalog as well. But when I run the python script as a scheduled task it seems to run but the data doesn't sync between the databases. I also tried the option of setting up a scheduled task to run a python script / bat file that calls the model itself. This doesn't seem to process properly. Not sure what I am missing but I'm not familiar with python so I don't really know where to begin. Any ideas are appreciated.
Sharon
BruceBacia
We had this problem the other day at work.  Instead of "Database Connections\\SQL [email protected]\\GISPW.OWNER.PW_SewerNetwork", you must list the full path to the sde connection.
KenCarrier
This handy little piece of code should help get you started
Run the code below in IDLE or whatever IDE you are using for python:
for k in os.environ: print "%s: %s" %(k, os.environ)
This will give you a list of all the environment variables you can reference to make building your paths easier.
Once you have a look at the above try to follow this, this will list all the sde connections in your DatabaseConnections folder.
import os, arcpy
from arcpy import env
path = os.path.join(os.environ['APPDATA'],'ESRI\\Desktop10.1\\ArcCatalog')
env.workspace = path
workspaces = arcpy.ListWorkspaces("*","SDE")
for workspace in workspaces:
    print workspace
Hope this helps!
BruceBacia
Many thanks for the tips Ken!  Very useful
