Trying to Back Up Hosted Feature Service
4314
08-24-2014 05:16 PM
MarkTukman
Does anyone have a good solution to backing up a hosted feature service using python, so a local backup can be run in task scheduler (preferably as a python script)?  I tried to do this using Create Replica and the requests library, but it doesn't seem to be working.  Does anyone know why the following python doesn't work?
import requests, json
payload={"geometry": '',
    "geometryType": "esriGeometryEnvelope",
    "inSR": '',
    "layerQueries": '',
    "layers": "0",
    "replicaName": "read_only_rep",
    "returnAttachments": 'true',
    "returnAttachmentsDataByUrl": 'true',
    "transportType": "esriTransportTypeURL",
    "async": 'false',
    "syncModel": "none",
    "dataFormat": "filegdb",
    "replicaOptions": '',
    "f": "html"}
payload2 = json.dumps(payload)
r2 = requests.post('http://services2.arcgis.com/Pw6oQMuXLspbq6zz/arcgis/rest/services/SON_ROADS/FeatureServer/createRepl...', data=payload2)
XanderBakker
Esri Esteemed Contributor
It seems there is something wrong with the transportType "esriTransportTypeURL". I changed the code to use urllib and urllib2 and it returned the following error:
{"error":{"code":400,"message":"","details":["'transportType' parameter is invalid"]}}
I changed the transportType to esriTransportTypeEmbedded and that did return a link to a ZIP file.
import json
import urllib
import urllib2
    "inSR": '',
    "layerQueries": '',
    "layers": "0",
    "transportType": "esriTransportTypeEmbedded",
    "async": 'false',
    "f": "json"}
url = 'http://services2.arcgis.com/Pw6oQMuXLspbq6zz/arcgis/rest/services/SON_ROADS/FeatureServer/createRepl...'
data = urllib.urlencode(payload)
req = urllib2.Request(url, data)
response = urllib2.urlopen(req)
json_out = response.read()
print json_out
This printed:
{"transportType":"esriTransportTypeUrl","responseUrl":"http://services2.arcgis.com/Pw6oQMuXLspbq6zz/ArcGIS/rest/services/SON_ROADS/replicafiles/8c8720356d6..."}
The ZIP contains the fgdb.
Kind regards, Xander
XanderBakker
import json
import urllib
import urllib2
    "inSR": '',
    "layerQueries": '',
    "layers": "0",
    "async": 'false',
    "f": "json"}
print json_out
This printed:
TrilliumLevine1
Hi Xander,
I'm trying to make a script for replicating secured AGOL-hosted services to a local disk.  I know I have to use a token for this, so I've tried integrating your code with the standard token code (see below), but it's not working for me.  The token is printing, but then it's followed immediately by another message indicating that a token is needed (see screenshot).  I know I must be missing something simple, but am not sure what it is...any ideas?  Feedback is greatly appreciated!
import json, urllib, urllib2, os
USERNAME = "username"
PASSWORD = "pw"
REFER = "www.arcgis.com"
def urlopen(url, data=None):
    referer = "http://arcgis.com/arcgis/rest"
    req = urllib2.Request(url)
    req.add_header('Referer', referer)
    if data:
        response = urllib2.urlopen(req, data)
    else:
    return response
def gentoken(username, password, referer, expiration=60):
    #Re-usable function to get a token
    query_dict = {'username': username,
                  'password': password,
                  'expiration': str(expiration),
                  'client': 'referer',
                  'referer': referer,
                  'f': 'json'}
    query_string = urllib.urlencode(query_dict)
    tokenUrl = "https://www.arcgis.com/sharing/rest/generateToken"
    tokenResponse = urllib.urlopen(tokenUrl, urllib.urlencode(query_dict))
    token = json.loads(tokenResponse.read())
    if "token" not in token:
        print token['messages']
        exit()
    else:
        # Return the token to the function which called for it
        return token['token']
token = gentoken(USERNAME, PASSWORD, REFER)
print token
    "inSR": '',
    "layerQueries": '',
    "layers": "0",
    "async": 'false',
    "f": "json"}
url = 'http://services1.arcgis.com/0cr41EdkajvOA232/arcgis/rest/services/Forstmobil_WV_Daten_view/FeatureSe...'
print json_out
DamianoMontrasio
