Truncating String in Python
16760
6
06-10-2011 11:44 AM
MikeMacRae
I have poured through the internet trying to find a way to truncate a string in Python and I am at a wall.
I want to truncate a string like this:
My_String_Needs_to_be_truncated_12May11_mm
I want to truncate this portion "_12May11_mm" so that I have "My_String_Needs_to_be_truncated" remains.
Thanks for any help!
Mike
JasonScheirer
Esri Alum
What do other strings of the same form look like? Do you need to truncate to a length or a number of fields?
x = "My_String_Needs_to_be_truncated_12May11_mm"
truncated = x[:31]
or
truncated = x.rsplit("_")[0]
etc. What do other samples of strings you need truncating look like?
DarrenWiens2
If you want to remove a certain number of characters from the right, use rstrip(). Alternatively, you can return a list of "words" contained in a string separated by a given character using split(), then keep the ones you want. Your best bet is to Google "python string operations".
MikeMacRae
Hey thanks for the replies.
Jason, all my strings look like that. They all end exactly like my example with a "_12May11_mm" The exact amount of characters in that portion never changes (11) because I only change the date and the "mm" are my initials. If another user will be using my profile, the initials may change, but it's always just 2 characters. The amount of characters in the leading portion (My_String_Needs_to_be_truncated) can and will change often, so I wanted to tackle this from the last portion because it is more consistent.
Basically, this is the the format of my mxd file names. When my program updates the mxd, I want to resave the file with the current date and the users initials. I have a line that can do the update, I am just having trouble seperating the file name and then grabbing that first portion into a variable or something. Below is my code for updating the file name. I would like to store the "My_String_Needs_to_be_truncated" into the variable "sitename"
"Path Name:"  + outloc + "\\" + sitename + "_"  + "_" + strftime("%y%b%d") + "_" + user
TerrySilveus
Here's a couple more options
# this option removes the 11 right characters (if you know it will always be 11)
x = 'My_String_Needs_to_be_truncated_12May11_mm'
print x[0:-11]
# this option builds the string after putting it into an array split at the "_" and removing the last two elements
y = x.split("_")
y.pop()
y.pop()
z = ""
i = 1
for word in y:
    if i == 1:
        z = z + word
    else:
        z = z + "_" + word
    i = 2
print z
JasonScheirer
Esri Alum
Ah, if it's always the same like that then you can do this:
tail_to_clip = "_12May11_mm"
truncated = x.rsplit("_")[:-len(tail_to_clip)]
And then just swap out tail_to_clip as needed. Though the option with rstrip is a bit more robust.
MikeMacRae
Thanks everyone, for the help. I used a combination of your suggestions and now that portion of my script works perfectly!
Cheers,
Mike
