Trouble using "in_memory" to temporarily store geomety
5365
11
04-14-2014 07:02 AM
JamesMcBroom1
Here's my script that I'm writing before I convert it into an Add-in button. It seems like it's actually creating a feature class called "in_memory" in my default.gdb...
layers = get_layers() bigArea = 0 bigAreaPIN = None with arcpy.da.SearchCursor(layers['parcels_fc'], ["Shape_Area", "PIN10"]) as rows:     for row in rows:         if row[0] > bigArea:             bigArea = row[0]             bigAreaPIN = row[1]         else: pass  del rows  print bigArea, bigAreaPIN  arcpy.Dissolve_management(layers['parcels_fc'], "in_memory")  with arcpy.da.SearchCursor("in_memory", ["SHAPE@"]) as rows:     for row in rows:         newPolygon = row[0] del rows  subparcels = []  with arcpy.da.UpdateCursor(layers['parcels_fc'], ["PIN10", "SHAPE@"]) as rows:     for row in rows:         if row[0] == bigAreaPIN:             row[1] = newPolygon             rows.updateRow(row)         else:             subparcels.append(row[0])             rows.deleteRow() del rows  with arcpy.da.InsertCursor(layers['superparcel'], ["original", "superparcel"]) as insert:     for x in subparcels:         insert.insertRow((x,bigAreaPIN)) del insert  arcpy.RefreshActiveView() arcpy.Delete_management("in_memory")
Any idea what I'm doing wrong here?
MathewCoyle
Honored Contributor
Use
arcpy.env.overwriteOutput = True
I'm not sure why delete wouldn't remove your temp feature class unless you are mixing workspaces. in_memory is process specific, so if you run a tool from one instance, another instance would not be referencing the same in_memory workspace.
MathewCoyle
Honored Contributor
Yes, that is exactly what you are telling it to do. If you want to actually utilize the in_memory workspace you must include that as a path.
arcpy.Dissolve_management(layers['parcels_fc'], r"in_memory\working")
arcpy.da.SearchCursor(r"in_memory\working", ["SHAPE@"])
JamesMcBroom1
OK - I am now seeing the correct in_memory title in the TOC sources, and the script works fine.
But when I try and run it a second time, I get another error telling me that dataset in_memory/dissolved already exists, even though:
arcpy.Delete_management(r"in_memory/dissolved") returns True.
But then I try:
arcpy.Exists(r"in_memory/dissolved")
and that returns True. How can this be? Is it because I am working from the Python console?
MathewCoyle
Honored Contributor
Use
JamesMcBroom1
Using..
The process runs again, but on the 2nd time around it updates with the newPolygon geometry from the 1st time.
MathewCoyle
Honored Contributor
How are you executing this code? Through an add-in? Toolbox? Something else?
JamesMcBroom1
I write in PyScripter and then copy-and-paste into the ArcMap python window. Once it 'works' that's when I will drop the code into an add-in that I can share with my colleagues.
benberman
The correct syntax for in_memory is "in_memory\\file". When you want to clear in memory you should simply do
JamesMcBroom1
Changed my code to include the double slash and I'm still getting an error about in_memory/dissolved existing when I run the script for a second time.
JamesCrandall
I didn't fully review your codebase, but when I am doing iterative intermediate data creation then I will simply use the in_memory space as temporary workspace for the iteration.  That is, once a proc/step is complete then I remove everything from the workspace.  Here's a def I add to my .py file and simply call from the loop(s)
 def clearINMEM():
     """ clear out the IN_MEMORY workspace of any featureclasses """
     arcpy.env.workspace = "IN_MEMORY"
     fcs = arcpy.ListFeatureClasses()
     ### for each FeatClass in the list of fcs's, delete it.
     for f in fcs:
         arcpy.Delete_management(f)
