this is a code from VBA...since ESRI now abandoned VBA I need it in python!
3844
10
06-05-2013 05:18 AM
DanielAmrine
Attached is .py of the code converted to Python syntax....
however i need to call in arcpy and then change some more of the syntax to fit the current python language...I'm new to this and i was not very good with VBA....but we need this functionality in our workflow!! So any help is much appreciated!
RhettZufelt
MVP Notable Contributor
1.) How does VBA still work? I know 10.0 still supports it but you need the VBA extension. (A pain to get the authorization code)...
10.1 and beyond no longer supports VBA...supposedly.
Dan
I just contacted the customer care center and they authorized the VBA, then downloaded the authorizations from the customer care portal.
Pretty painless actually,
R_
