Test if SDE feature class is part of a feature dataset?
1003
05-27-2011 01:02 PM
mvisekru
Is there a way in ArcPy to test a featureclass in order to see if it is part of a featuredataset + get the name of the featuredataset?
Thanks!
AnthonyFarndon
Not the most elegant solution which I have not tested, so hopefully someone has a better suggestion....
If you are calling this often in your code, you could create a dictionary of the geodatabase contents, and then run you tests against that
import arcpy
arcpy.env.workspace = "yourdegeodatabase.sde"
fcDict = {}
#loop through and fill dictionary
dsList = arcpy.ListDatasets()
for ds in dsList:
    fcList = arcpy.ListFeatureClasses("*","",ds)
    for fc in fcList:
        fcDict[fc] = ds
#test
myFC = arcpy.Describe("thefciwanttotest")
if myFC.name in fcDict:
    print fcDict[myFC.name]
If it is a once only call in your script for one featureclass, this is a little more streamlined, again not tested.
import arcpy
#loop through
for ds in dsList:
    fcList = arcpy.ListFeatureClasses(myFC.name,"",ds)
    for fc in fcList:
        print ds
curtvprice
Thanks!
Here's my suggestion:
import arcpy, os
def GetFDS(FC):
  """ Returns the feature dataset for a feature class
  or feature layer FC.
  If the feature class is not within a feature dataset,
  returns None."""
  # get the path to the feature class
  fcPath = arcpy.describe(FC).catalogPath
  # get the path to its container
  fcHome = os.path.dirname(fcPath)
  # is it a feature dataset??
  if arcpy.describe(fcHome).dataType == "FeatureDataset":
    return fcHome
  else:
    return None
