SWITCH_SELECTION in SelectLayerByLocation_management
3955
10-27-2015 06:22 AM
GyeyoungChoi
import arcpy,sys
sdeConn = r"Database Connections\\Test.sde"
muniLoc = "Municipalities"
luLoc = "Land_Use"
tempLoc = "tempMuniLuRatio"
lu_lyr = "lu_lyr"
arcpy.env.workspace = sdeConn
try:
  print "MakeFeatureLayer_management lu_lyr"
  arcpy.MakeFeatureLayer_management(luLoc, lu_lyr)
  prematchcount = int(arcpy.GetCount_management(lu_lyr).getOutput(0))
  print "MakeFeatureLayer_management muni_lyr"
  #arcpy.MakeFeatureLayer_management(muniLoc, "muni_lyr")
  #print "SelectLayerByLocation_management NEW_SELECTION"
  #arcpy.SelectLayerByLocation_management(lu_lyr, "COMPLETELY_CONTAINS",muniLoc,"","NEW_SELECTION")
  print "SelectLayerByLocation_management SWITCH_SELECTION"
  arcpy.SelectLayerByLocation_management(lu_lyr, "COMPLETELY_CONTAINS",muniLoc,"","SWITCH_SELECTION")
  postmatchcount = int(arcpy.GetCount_management(lu_lyr).getOutput(0))
  if prematchcount == postmatchcount:
  print "SelectLayerByLocation_management DID NOT WORK"
  else:
  print "SelectLayerByLocation_management LOOKS GOOD"
  if arcpy.Exists(tempLoc):
  print "Delete_management "
  arcpy.Delete_management(tempLoc)
  print "CopyFeatures_management "
  arcpy.CopyFeatures_management(lu_lyr,tempLoc)
except Exception:
  e = sys.exc_info()[1]
  print(e.args[0])
Result is just same as lu_lyr even after SWICH_SELECTION option.
Where should I take a look to make this work?
Jack
Tags (3)
DarrenWiens2
Is there a selection in your ArcMap session? It looks like you once made a selection and then commented it out.
If there is no prior selection, you are running up against a couple of quirks of GetCount​ and SelectLayerByLocation. 1.) GetCount returns the count of all features if there is no selection. Your variable "prematchcount" returns a count of all features because there is no selection. Later, "postmatchcount" returns a count of all features, because all features are selected. 2.) When you use "SWITCH_SELECTION", the second and third parameters are ignored, so there is no spatial component to the tool whatsoever at that point.
Luis_ÁngelPascual_Camino
Hi Gyeyoung.
I've been checking the syntax on Esri help.
I see that the 4th parameter "search_distance" is optional, but is a numeric parameter. So, what I think it is doing, is assume that you don't give an optional numeric parameter, and it reads the empty string as the 5th parameter. With other words, try this:
arcpy.SelectLayerByLocation_management(lu_lyr, "COMPLETELY_CONTAINS",muniLoc,0,"SWITCH_SELECTION")
...giving zero instead of empty strig "". I think it will take it as the numeric 4th parameter, and after it will execute your switch selection.
Hope it helps. Good luck!
Luis Pascual
DarrenWiens2
curtvprice
Darren is right on with SWITCH_SELECTION. Maybe you really meant "REMOVE_FROM_SELECTION"?
To avoid confusion, I always use SWITCH_SELECTION in my code with SelectLayerByAttribute (simpler syntax):
arcpy.SelectLayerByAttribute(lyr, "SWITCH_SELECTION")
NeilAyres
And there is a whole bunch of indentations after the ifs that need to be sorted out.
