Strange string truncation in ArcToolbox
793
10-10-2011 05:21 AM
pierocavalieri
Hi all,
I have a simple Python script, which should check if a text file exists, and if not, create it:
filename = "%s\\%s.sql" % (sqlDir,viewName)
gp.AddMessage("Sql file: " + filename)
if not os.path.exists(filename):
  ecc.
Running the script from an IDE (I use PyScripter) it works fine (the debugger also displays correctly the filename)
Running it from the ArcToolbox, the directory part of the file path is removed, i.e. gp.AddMessage("Sql file: " + filename) prints only "\\viewName", so the line
Can anyone explain me why this weired behaviour ?
DanPatterson_Retired
did you try this for your replace?
filename.replace("\\", "/")
pierocavalieri
Sorry, it was my mystake. When using:
gp.GetParameterAsText(pos_dir)
pos_dir was not correct (but was correct in PyScripter...)
Piero
