Splitting raster cells.
889
03-03-2013 06:40 PM
TLeed
I have a raster with a resolution of .47-meters, it contains one field that defines the presence or absence of forest canopy (1 or 0).
I need to use a 5-meter fishnet, (or 5-meter raster) to average the coverage within each each cell.   The 5-meter raster obviously doesn't line up perfectly with the .47-meter raster.   How do I get the exact percent coverage of the underlying forest canopy coverage into the 5-meter raster or fishnet.
Doing a block statistic works, but when I run it with snap raster it changes the values to back to 1 or zero.   I thought there might be a good solution using python.
I could also convert them to polygon features, but I'm surprised there isn't a good way to do it with 2 rasters.
Thanks in advance for your help!:confused:
MathewCoyle
Honored Contributor
Could you use focal statistics with 5m map units and then just con to your 5m raster?
curtvprice
The tool you are looking for is Aggregate. You can't get an "exact" aggregation - as .47 does not equally divide into 5 -- but it will be very close if you resample on the fly at a smaller cell size (.2) that equally divides into 5 meters.
from arcpy.sa import *
arcpy.env.cellSize = 0.2
# .2m * 25 = 5m (you could also use other values, say 0.1 and 50)
fiveMeterMean = Aggregate("p47rast",25,"MEAN")
# to get 0-100 percents:
fiveMeterPct = Aggregate("p47rast",5,"MEAN") * 100
