SPEED:  da.UpdateCursor vs. field calculation?
4119
12-28-2012 08:28 AM
KevinBell
I need to add 12 integers together for 1.5 billion points.  Would it be faster to do in a da.UpdateCursor or should I just use the standard field calculator?
by Anonymous User
Not applicable
I would go with the update cursor (especially at 10.1).  In my experiences, update cursors are about waaaay faster than the field calculator or Calculate Field tool.  I used to have a script that would run 6 field calculations on a table with only 20,000 records that used to take about 15 minutes.  With update cursors (and dictionaries) the execution time is down to just under a minute.  You won't be able to use dictionaries with an update cursor on a table with 1.5 billion records, but I think using an update cursor by itself will definitely work much faster than field calculations.
KevinBell
half a billion in one hour w/ da.updateCursor so far.  So 2 hrs to finish...  It took about 40 hrs w/ the field calculator.
JamieKass
Any input from ESRI folks on why this is true? I have had the same experiences where UpdateCursor is much faster than CalculateField, even when switching to 'VB', which is the recommended way to speed it up. What is CalculateField doing that slows it down? Shouldn't it simply run an UpdateCursor? Or is something else going on behind the scenes?
