Spatial Join ERROR 000725: Output Feature Class: GISLAYER already exists
3264
06-29-2011 01:18 PM
AshakaThakore
I created a simple model, it has spatial join, it takes two feature classes (parameters are hardcoded) and then does a spatial join and the outputs the joined features. The output feature class is also hardcoded.
I want to do a spatial join and the output should be overwritten to that hardcoded feature class...
It works fine in model builder, But when i export that model to python script and i run that python script i get this error -
LoganPugh
See: http://blogs.esri.com/Dev/blogs/geoprocessing/archive/2011/06/24/ExportModelToPy.aspx
Specifically add arcpy.env.overwriteOutput = True before your spatial join operation.
AshakaThakore
thanks ...
i am using 9.3 so this worked for me
gp.overwriteoutput = True
thanks again
