Spatial Join & Dictionary transfer
4106
10
07-27-2022 08:58 AM
2Quiker
I have a two layers, I need to transfer a field attribute to the other layer of the selected feature.
The EMS layer has a filed "SiteCity" and so does the "Ass_Parcels" layer.
I need to transfer the Ass_Parcels SiteCity attribute to the EMS's SiteCity field.
I have the following but I am not able to get it to work.
I don't get an error, but the EMs's SiteCity field doesn't get populated.
pointLayer = 'EMS'
parcel = 'Ass_Parcels'
ptCount = int(arcpy.GetCount_management(pointLayer).getOutput(0))
dsc = arcpy.Describe(pointLayer)
selection_set = dsc.FIDSet
if len(selection_set) == 0:
    print "There are no features selected"
elif ptCount >= 1:
elif ptCount >= 1:
    arcpy.SpatialJoin_analysis(pointLayer, parcel, sjpoints)
    search_feats ={f[0]:(f[1:]) for f in arcpy.da.SearchCursor(sjpoints,'SiteCity_1')}
    print(search_feats)
    with arcpy.da.UpdateCursor(pointLayer,["SHAPE@","SiteCity"]) as upd_cur:
        for upd_row in upd_cur:
            try:
                if search_feats[upd_row[0]][1] == "Sea":
                    upd_row[1] == "Seattle"
                elif search_feats[upd_row[0]][1] == "Spo":
                    upd_row[1] == "Spokane"
                elif search_feats[upd_row[0]][1] == "Tac":
                    upd_row[1] == "Tacoma"
                upd_cur.updateRow(upd_row)
            except:
               continue
2Quiker
apologizes for the delay response, I got busy with something else.
The print(search_feats), prints {u'Ros': ()}
I have attached the data I am working with, if it helps.
I changed the parcel data to City limits to help with the size of the up loaded file.
I need to update the pointLayer = EMS points2 SiteCity field with the
Parcels =  CityLimits1 SiteCity field
pointLayer = 'EMS_Points2'
city = 'CityLimits1'
sjpoints = "In_memory\sjpoints"
elif ptCount >= 1:
    #Run the Spatial Join tool, using the defaults for the join operation and join type
    arcpy.SpatialJoin_analysis(pointLayer, city, sjpoints)
    search_feats ={f[0]:(f[0]) for f in arcpy.da.SearchCursor(sjpoints,'SiteCity_1')}
    print(search_feats)
##    with arcpy.da.UpdateCursor(pointLayer,["SHAPE@","SiteCity"]) as upd_cur:
##        for upd_row in upd_cur:
##            try:
##                if search_feats[upd_row[0]][1] == "Sea":
##                    upd_row[1] = "Seattle"
##                elif search_feats[upd_row[0]][1] == "Spo":
##                    upd_row[1] = "Spokane"
##                elif search_feats[upd_row[0]][1] == "Tac":
##                    upd_row[1] = "Tacoma"
##                upd_cur.updateRow(upd_row)
##            except:
##               continue
    place_dict = {"Sea":"Seattle", "Spo":"Spokane", "Ros":"Roslyn"}
            try:
                upd_row[1] = place_dict.get(search_feats[upd_row[0]][1], upd_row[1])
            except:
               continue
