Spaces
1493
09-21-2022 01:24 PM
SLouq
by MVP Alum
MVP Alum
Supposed I have a string '111 SPEASST' in my table but want to make it
111 S PEAS ST
What is the Python Expression I could use in the Calculate Field parser to accomplish this
DavidSolari
MVP Regular Contributor
I assume you're trying to clean up address data, which doesn't have a generic solution. If it's the same error over and over you can use string methods such as .index, .split, .join, slicing etc. to fix the error, here's an example that'll work for your example string:
def fixAddr(x):
  sNum, sData = x.split()
  sDir = sData[0]
  sName = sData[1:-2]
  sType = sData[-2:]
  return f"{sNum} {sDir} {sName} {sType}"
If you want a generic method, the only technique I can think of is to run your address string through a geocoder and then pull out the component parts from the returned address. This is much more complex than just basic field calculation but it's the most bulletproof method I've found. Good luck!
DavidSolari
def fixAddr(x):
  sDir = sData[0]
  sName = sData[1:-2]
  sType = sData[-2:]
DeanAnderson2
Here are a bunch of examples of how to play with python strings (slice, modify, etc).
https://www.w3schools.com/python/python_strings.asp
