[SOLVED]How To Run .py Script
1569
05-08-2012 09:46 AM
JoelMadero
Hi All,
I've got a py script that I made but can't figure out how to actually run it in arc. When I try to right click and add it to the toolbox the option is grayed out. Thanks in advance
JakeSkinner
Esri Esteemed Contributor
If you are trying to add the script to a toolbox, make sure you are not trying to add it to a System Toolbox (i.e. Data Management Tools).  Create your own toolbox by right-clicking on a Folder or Geodatabase > New > Toolbox.  You can then add the python script to this toolbox.
JoelMadero
Thanks to both of you. After closing GIS and trying it again I was able to create a toolbox and add it (before it wasn't letting me add one). Script is running 🙂
