SetMDomain not working
1339
01-02-2012 06:17 PM
RogerLoweth
Anyone know why this doesn't work:
sr = arcpy.Describe(my_bathy).spatialReference
sr.setMDomain(-100000, 100000)
ZM are both enabled for my_bathy.
Thanks, Roger
DuncanHornby
MVP Notable Contributor
Roger,
I just tried the following code on a river network I have and it did not produce an error.
# Layer name in Map Document
s = "Rivers"
# Describe object and print name string to confirm it worked
desc = arcpy.Describe(s)
print desc.namestring
# Get spatial reference and print name
sr = desc.spatialreference
print sr.name
# Get FeatureClass and check if M aware
fc = desc.featureclass
print fc.hasm
# Set M domain
sr.setmdomain( -1000,1000)
This would suggest that there is something odd with your layer as your code looks sound?
Duncan
RogerLoweth
Thanks Duncan,
Finger trouble with upper/lower case - misdirection from ESRI helpfile.
Cheers, Roger
Roger,
s = "Rivers"
print sr.name
print fc.hasm
# Set M domain
Duncan
