Set Environment parameter in custom geoprocessing tool
1157
05-23-2025 12:20 PM
EugeneSosnin_GSI
I build a new geoprocessing tool, and I want to set a default outputCoordinateSystem in Environment:
I found we have it tool parameters:
I tried to use initializeParameters:
class ToolValidator:
  # Class to add custom behavior and properties to the tool and tool parameters.
    def __init__(self):
        # Set self.params for use in other validation methods.
        self.params = arcpy.GetParameterInfo()
    def initializeParameters(self):
        # Customize parameter properties. This method gets called when the
        # tool is opened.
        for param in self.params:
            if param.name == "outputCoordinateSystem":
                param.value = arcpy.SpatialReference(2230)
        return
 but it didn't work out.
Could you, please, help me?
HaydenWelch
MVP Regular Contributor
Your parameter name is the Name field. that is not 'outputCoordinateSystem' in your screenshot, but 'output_feature...'
You can also just manually set the environment variable using arcpy.env:
import arcpy
def main():
    arcpy.env.outputCoordinateSystem = arcpy.SpatialReference(2230)
EugeneSosnin_GSI
Thank you for the answer.
Yeah, I am still confused how to set the Environment parameter. Therefore, I could not accept the answer.
Currently, I use:
def main():
    with arcpy.EnvManager(outputCoordinateSystem='PROJCS["California_...'):
        arcpy.management.CopyFeatures(path, outpath)
