Set a map view scale
2028
7
08-04-2025 04:42 AM
Sfortunatamente
Hi, it should be pretty simple, I know but I'm stuck. I have one layer, I grab the extent of it and set the defaultCamera extent based on that value. This is my "pan to layer". Now I need to zoom in to a, let's say, 1:1000 scale. How can I do that?
Marshal
Set the scale property of camera.
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/camera-class.htm
aprx = arcpy.mp.ArcGISProject('CURRENT')
layout = aprx.listLayouts()[0]
map_frame = layout.listElements('MAPFRAME_ELEMENT')[0]
map_frame.camera.scale = 1000
Sfortunatamente
Thanks. I still do not get it. I do not have any layouts, just a simple map frame. I get an empty list:
lyt = aprx.listLayouts()
Marshal
If you are not using a map frame in a layout then you must use aprx.activeView > MapView.camera.scale.  But it is only intended for use while ArcGIS Pro is open (e.g. script tools, python window, etc.).
https://pro.arcgis.com/en/pro-app/latest/arcpy/mapping/mapview-class.htm
That said, why would you need to set the scale on a map if you aren't exporting it?  If you are exporting it, why wouldn't you use a layout?
Sfortunatamente
I need to set up the extent and scale for publishing the map so anytime I add the map service to a web map the content is already in place. Is there a better approach for that?
I will execute the py script from the command line later on without opening ArcGIS Pro
Marshal
You are publishing the layers in the map as a map service?  The scale and extent of the map used for publishing has no impact on the resulting map service.
Sfortunatamente
You're right. Thanks!
TonyAlmeida
MVP Regular Contributor
Set the extent to the layer
mf.camera.setExtent(mf.getLayerExtent(lyr, True, True))
aprx = arcpy.mp.ArcGISProject("CURRENT")
# Get map and layer
m = aprx.listMaps("Layers1")[0]
lyr = m.listLayers("CCSO.CCSO.CCAP")[0]
# Get layout elements
lyt = aprx.listLayouts("Layout1")[0]
mf = lyt.listElements("MAPFRAME_ELEMENT", "Map Frame")[0]
# First set the extent to the layer
# Then set the target scale (1:1000 in your case)
target_scale = 1000  # Changed to 1000 as per your question
mf.camera.scale = target_scale
# Update the map's default camera if needed
m.defaultCamera = mf.camera
